pro charger vs turbo #1348684
12/09/12 09:17 PM
12/09/12 09:17 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
If you were to build a 450"ish street/strip motor around 2000 hp on alcohol
Would you use a race drive Prochatger or twin turbos?
Re: pro charger vs turbo [Re: Big B] #1348685
12/09/12 09:26 PM
12/09/12 09:26 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
procharger
never thought i would post this here but in on 1
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: pro charger vs turbo [Re: bigtimeauto] #1348686
12/09/12 09:36 PM
12/09/12 09:36 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
Would a a F3 Procharger with race drive last on the street?
Re: pro charger vs turbo [Re: Big B] #1348687
12/09/12 09:41 PM
12/09/12 09:41 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Depends on your definition of a street car. I run a side slinger and am not afraid to drive it 30 miles. A race drive will eat bushings and the blower might try to eat something sitting down there.other than packaging sure why not.
Re: pro charger vs turbo [Re: bigtimeauto] #1348688
12/09/12 09:52 PM
12/09/12 09:52 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
30 miles isn't going to cut it. I'd like to be able to drive 1000 miles trouble free. Not sure if a Pro charger can do that.
Re: pro charger vs turbo [Re: Big B] #1348689
12/09/12 09:55 PM
12/09/12 09:55 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
on one trip? I don't even like driving mine on the street anymore since 25.5ing it.
Is this a drag week deal?
Re: pro charger vs turbo [Re: bigtimeauto] #1348690
12/09/12 09:57 PM
12/09/12 09:57 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
not to mention how big of a fuel tank you going to run on alky? you won't even be able to go 30 miles on a tank.
Re: pro charger vs turbo [Re: bigtimeauto] #1348691
12/09/12 10:00 PM
12/09/12 10:00 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
I would. Like to build a drag week type deal. On the street I will just run pump gas.
Re: pro charger vs turbo [Re: Big B] #1348692
12/10/12 12:20 AM
12/10/12 12:20 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
Turbo....
Re: pro charger vs turbo [Re: SLOW67] #1348693
12/10/12 01:18 AM
12/10/12 01:18 AM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
Procharger would be my choice but 2000 hp at 450 ish cid would likely be of very limited use on the street. I seem to recall some procharged applications that pulled the belt for the drive so not really sure what is possible. My combination should be good for a little more than 2000 hp but has no cooling and would need to haul a fuel tanker behind it to go anywhere.
76 Duster work in progress
Re: pro charger vs turbo [Re: Edge] #1348694
12/10/12 01:29 AM
12/10/12 01:29 AM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
I basically want to build a Larry Larson type deal just not as fast.
I want to get good gas mileage. Hence the smaller cubes. Just run pump gas on the street and race gas at the track.
Re: pro charger vs turbo [Re: Big B] #1348695
12/10/12 04:02 AM
12/10/12 04:02 AM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
I know mileage has improved with the progress with Turbos, EFI, etc & off boost will help with fuel economy.
I also guess, it depends on how much slower than Larry Larson you want to be...
To be in a similar league, my expectations, would not include good fuel economy, as one of the criterias
Re: pro charger vs turbo [Re: mopar_mark] #1348696
12/10/12 11:33 AM
12/10/12 11:33 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Cubic inch is not going to make a measurable difference in fuel mileage driving normal. Now under boost it will make a lot more horsepower.
I’m thinking Larson is at 3 thousand + horsepower.
If you are not racing anybody heads up the turbo (s) would be the easier way for you to achieve your goal without disconnecting the blower.
Re: pro charger vs turbo [Re: bigtimeauto] #1348697
12/10/12 11:51 AM
12/10/12 11:51 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Doesn't Larsons car go thru parts (rockers, springs...) every weekend? That is a serious race car. I guess it depends on how your welding skill are. A S/C would be easier but more expensive. Turbos are cheaper but require more fab work.
Coming soon!!!!
Re: pro charger vs turbo [Re: Mr.Yuck] #1348698
12/11/12 06:37 PM
12/11/12 06:37 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
For what you want to do, the turbo would be the best bet. It'd be simple to set up a boost control that limits your boost on pump fuel, but can be cranked up when you run on race fuel. I know of a supra that had two injectors per cylinder and two fuel tanks. A larger, pump gas, tank and a small race fuel tank. Not sure how the setup worked, but he could switch from street to race without hardly any grief. Just an idea. If it was purely race I would say the procharger might be the most simple setup, but for a dual purpose, I think turbos are the way to go.
Re: pro charger vs turbo [Re: dodgeboy11] #1348699
12/11/12 06:49 PM
12/11/12 06:49 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
I guess I am leaning towards turbo. My goal is a low 7 second car, but has to be extremely reliable/street able. I'm probably going to have The Race Shop in WI do the chassis and Goodwin Competition Race Engines build the motor. I've been saving for the last 6 years to build the car. I want it done perfectly.
I wouldn't beat Larry Larson on Drag week, but if I can finish could probably take top 10
Re: pro charger vs turbo [Re: Big B] #1348700
12/13/12 03:20 PM
12/13/12 03:20 PM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
TURBO!!!
I've had both!! Prefer a Turbo any day!!! A lot more technical to setup BUT once it is setup a lot easier to work with.
Re: pro charger vs turbo [Re: Big B] #1348701
12/13/12 03:53 PM
12/13/12 03:53 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm not going to call your dream far fetched, by the words 7 second and extremely reliable/streetable is going to be some feet. No too mention extremely expensive, like in the 150k+ range. Don't let those cars fool you the are anything but "street cars" They are all out race cars w/ a few street items, not to mention the constant maintance they require. If 7's are your goal I suggest buying an ex-pro-stock car and adding lights, wipers, windows that roll down and a radio. Because by the time you are done, that's what you'll have. have you talked to any of those guys? See if you can find some of the old posts about drag week on here. See how many times Eddie had his engine apart then back together then apart again in one weekend.
I wish ya luck
