Re: High Revving Small Blocks Anyone?
[Re: Sb Valiant]
#1348308
12/09/12 11:43 AM
12/09/12 11:43 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I turn my W-2 to 8200... same with my W-9 but have had it as high as 9600.. just drilled all the oil holes larger ported the pump on the W-2.. my W-9 is a R3 block with a dry sump.... all my rockers are T&D EDIT Both of these have a 3.79 crank... W-2 is 395ci and the W-9 is 405ci
[Re: jg309]
#1348310
12/09/12 01:34 PM
12/09/12 01:34 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
been to 10500 with 366 r3-w9 on dino
WOW that's crankin' What do you use for bottom end components?
[Re: 1967dartgt]
#1348314
12/09/12 08:28 PM
12/09/12 08:28 PM
Posts: 2,026 Trumbull,CT.
jim sciortino
Trumbull,CT.
417ci R3-W8....shift in the mid 8s, cross around 9.
External wet sump and Jesel rockers/Ti valves.
Have you run your car yet? Any times you want to share?
I shift mine at 7200-7300, r1a w9rp, wet sump ported and drilled, oil through push rods,etc.
Just some highway fun.
Looks like my pop won't be well enough to relieve us at the shop any time soon, so I guess we'll have to wait for a Sunday at ATCO in the spring.
[Re: ValiantRich]
#1348316
12/09/12 09:06 PM
12/09/12 09:06 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
15 years ago I was shifting a bored out 360 with a stock cast crank at 8,000 and turning 8,600 at the stripe. Stock style high volume oil pump. Harland Sharp rockers.
20 years ago same short block with J heads and crane rockers spun it fairly hard too just did not make power over 8,000.
[Re: Leon441]
#1348318
12/10/12 08:23 PM
12/10/12 08:23 PM
Posts: 624 Baltimore,MD
lowbudget
mopar addict
mopar addict
Baltimore,MD
What did you turn your NOS W8 motor to?
