High Revving Small Blocks Anyone? #1348307
12/09/12 11:03 AM
12/09/12 11:03 AM
western PA
Sb Valiant Offline OP
western PA
Anyone turn there small block mopars over 8,000 rpm? If so what kind of oiling system or valve train is required to do that?
Re: High Revving Small Blocks Anyone? [Re: Sb Valiant] #1348308
12/09/12 11:43 AM
12/09/12 11:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I turn my W-2 to 8200... same with my W-9 but have
had it as high as 9600.. just drilled all the oil holes
larger ported the pump on the W-2.. my W-9 is a R3
block with a dry sump.... all my rockers are T&D
EDIT
Both of these have a 3.79 crank... W-2 is 395ci and
the W-9 is 405ci
Re: High Revving Small Blocks Anyone? [Re: MR_P_BODY] #1348309
12/09/12 12:21 PM
12/09/12 12:21 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
been to 10500 with 366 r3-w9 on dino
Re: High Revving Small Blocks Anyone? [Re: jg309] #1348310
12/09/12 01:34 PM
12/09/12 01:34 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
WOW that's crankin'
What do you use for bottom end components?
Re: High Revving Small Blocks Anyone? [Re: 72demon416] #1348311
12/09/12 01:58 PM
12/09/12 01:58 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
417ci R3-W8....shift in the mid 8s, cross around 9.
External wet sump and Jesel rockers/Ti valves.
Re: High Revving Small Blocks Anyone? [Re: jim sciortino] #1348312
12/09/12 03:48 PM
12/09/12 03:48 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Have you run your car yet? Any times you want to share?
I shift mine at 7200-7300, r1a w9rp, wet sump ported and drilled, oil through push rods,etc.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: High Revving Small Blocks Anyone? [Re: 1967dartgt] #1348313
12/09/12 07:59 PM
12/09/12 07:59 PM
Saskatchewan (SK)
79410aspenrt Offline
Saskatchewan (SK)
362'' with w2 heads spinning to 8500 rpm
Re: High Revving Small Blocks Anyone? [Re: 1967dartgt] #1348314
12/09/12 08:28 PM
12/09/12 08:28 PM
Trumbull,CT.
Trumbull,CT.
Just some highway fun.
Looks like my pop won't be well enough to relieve us at the shop any time soon, so I guess we'll have to wait for a Sunday at ATCO in the spring.
Re: High Revving Small Blocks Anyone? [Re: jim sciortino] #1348315
12/09/12 08:49 PM
12/09/12 08:49 PM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
I shift my R3 W8 376" at 9400 and go over the line between 9800 and 10,000. External pump, wet sump, Jesel valvetrain.
Re: High Revving Small Blocks Anyone? [Re: ValiantRich] #1348316
12/09/12 09:06 PM
12/09/12 09:06 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
15 years ago I was shifting a bored out 360 with a stock cast crank at 8,000 and turning 8,600 at the stripe. Stock style high volume oil pump. Harland Sharp rockers.
20 years ago same short block with J heads and crane rockers spun it fairly hard too just did not make power over 8,000.
Re: High Revving Small Blocks Anyone? [Re: Leon441] #1348317
12/10/12 06:56 PM
12/10/12 06:56 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Lets ask this question, how many of you guys turning the motor over 8000rpm are running Stainless valves?
Re: High Revving Small Blocks Anyone? [Re: Leon441] #1348318
12/10/12 08:23 PM
12/10/12 08:23 PM
Baltimore,MD
lowbudget Offline
mopar addict
lowbudget  Offline
mopar addict
Baltimore,MD
What did you turn your NOS W8 motor to?
Re: High Revving Small Blocks Anyone? [Re: 79410aspenrt] #1348319
12/10/12 08:27 PM
12/10/12 08:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ya know some of us BB guys are not afraid of a litle RPM
Re: High Revving Small Blocks Anyone? [Re: lowbudget] #1348320
12/10/12 08:31 PM
12/10/12 08:31 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
8,600 is all I turned it. It had a 4.125" stroke and did not need to turn higher.
Re: High Revving Small Blocks Anyone? [Re: Leon441] #1348321
12/10/12 08:44 PM
12/10/12 08:44 PM
Baltimore,MD
lowbudget Offline
mopar addict
lowbudget  Offline
mopar addict
Baltimore,MD
How about a motor with 4.18x3.79 dragon slayer crank, cast intake single carb, cam is .280in 288ex at.050 .690 gross lift 1.65 rocker...what kind of RPM on something like that. I usually shift at 8000 and tried 8500 but it didnt make much difference so stayed at 8000
