Tire Recommendation???? #1348171
12/08/12 10:31 PM
12/08/12 10:31 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
What brand tires do you guys like to run on your street Mopars? Radial TAs???
Re: Tire Recommendation???? [Re: mopowers] #1348172
12/08/12 10:51 PM
12/08/12 10:51 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I have BFG G-force sports, but I think they only come in 225/60-15 anymore for any wheels less than 16". Much, Much, Much better traction than Radial T/As. They are directional summer only tires.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Tire Recommendation???? [Re: goldduster318] #1348173
12/08/12 10:58 PM
12/08/12 10:58 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I'm thinking of going with 255/60/15s MT drag radials in the back. what should I run in front to match those???
Re: Tire Recommendation???? [Re: mopowers] #1348174
12/08/12 11:58 PM
12/08/12 11:58 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Cooper Cobra's are a good 15" tire that come in all the popular sizes..
Re: Tire Recommendation???? [Re: mopowers] #1348175
12/09/12 12:26 AM
12/09/12 12:26 AM
Which application, the toy or the other cars? The toy gets M/T ET Street bias plys and the others get a good set of radials
Re: Tire Recommendation???? [Re: Cab_Burge] #1348176
12/09/12 12:38 AM
12/09/12 12:38 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Depends on what the intened use is. Long life? Track day or drag race? Somenthing to just roll around and load rating. I want a tire that has good summer tration, but will still be decent if Im in a rain storm that also has a decent life. Im also looking at maybe a 16" or 17" in an early A. I have been a fan of Michelin tires, especially the Pilots. Again, depends on intended use and budget.
Re: Tire Recommendation???? [Re: None2Slow] #1348177
12/09/12 12:48 AM
12/09/12 12:48 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
The car is a 68 Dart 340/727/3.91. The intended use is a street cruiser. It won't see a ton of miles so life isn't a huge deal to me.
Re: Tire Recommendation???? [Re: mopowers] #1348178
12/09/12 01:10 AM
12/09/12 01:10 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I run MT ET street radials and Pro-Trac front runners I know that guys will tell you horror stories about radials and bias plys not playing well together but my car handles fine even over 100 MPH
Gus
64 Plymouth Savoy
Dana 60
Re: Tire Recommendation???? [Re: fourgearsavoy] #1348179
12/09/12 01:11 AM
12/09/12 01:11 AM
Rittman Ohio
Rittman Ohio
Here is the stance
Gus
64 Plymouth Savoy
Dana 60
Re: Tire Recommendation???? [Re: fourgearsavoy] #1348180
12/09/12 01:56 AM
12/09/12 01:56 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I used to get Indy 500s from Firestone. Last set came in and said made in Mexico, even though the specs said USA. Kelly Chargers seem to be a good tire and are made in USA. Not sure about what sizes they make.
I want my fair share
Re: Tire Recommendation???? [Re: mopowers] #1348181
12/09/12 12:56 PM
12/09/12 12:56 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
What is your priority?
You get to make a choice; traction or wear life. As they get stickier, they wear faster.
I personally have 2 rear sets of wheels and tires. I tried very hard not to go this way because I wanted one set to do it all. But if you have any real horsepower numbers, it's just not possible.
I still enjoy a big smokey burn-out, and so does everyone else. That means street tires. And the brand is not terribly important. I can usually get 2 years or more out of street tires doing regular burn-outs.
If I have good sticky tires like drag radials, the acceleration is much better with the increased traction. But, it is easy to go through 2 or 3 sets of them an year doing roughly the same amount of burn-outs.
Besides, the street tires make for a much better burn-out overall. And the street tire burn-out is a much bigger crowd pleaser than brutal acceleration. Unless you are at the track or having a street grudge match.
Over the last 5 or 6 years, I think that the compromise of 2 different sets of wheels and tires has made my car more fun and actually saved me money since I have not bought several additional sets of sticky tires.
Besides, the sticky tires get hard after a year or so and start loosing their grip. They are not a good choice for a long term tire if the grip was the primary reason for purchase.
Frankly, more and more of the street tires are imports and are crap. But they are hard enough to last a good while. This choice can be made on price or looks alone.
The stickier tire choice is much tougher.
Master, again and still
Re: Tire Recommendation???? [Re: DaveRS23] #1348182
12/09/12 01:44 PM
12/09/12 01:44 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Gus I run Mickey bias rears and skinny radials front.No problems with my 65 either.Ive had it to 120 and can let go of the wheel and its still straight.Its not set up for road racing but it still handles gurves well.Rocky
Chrysler Firepower
Re: Tire Recommendation???? [Re: therocks] #1348183
12/09/12 02:41 PM
12/09/12 02:41 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
I run M/T street drag radials on the street, as big and as fat as I can get in the wheel wells.
BF goodrich's go up in smoke if you look at them menacing enough.
Mike
1969 Dodge Dart Swinger
Re: Tire Recommendation???? [Re: MikeyT] #1348184
12/09/12 02:58 PM
12/09/12 02:58 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Mike
How bout for fronts to match the MTs?
Re: Tire Recommendation???? [Re: mopowers] #1348185
12/24/12 01:46 PM
12/24/12 01:46 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
So, I'm still having trouble coming up with what tires to run. I need to run a 255/60/15 in back because that's the biggest I can get (whether it's a BFG T/A, Cooper Cobra, or MT Drag Radial, or a MT Sportsman S/T Radial). Those are pretty much my only options in that size.
Question 1- Which one of those will give me the grip and decent street manners?
Question 2- What's a good tire to match for the front in a 205/65/15 size??
None of those tires come in that size, so I'm going to be mixing. The guy at discount tire yesterday said it was a no-no to mix and match tires. I told him it's gonna be a hot rod and I'm not too worried about handling characteristics. I just wants something that looks decent with whatever rear tire I decide on.
Re: Tire Recommendation???? [Re: mopowers] #1348186
12/25/12 01:16 AM
12/25/12 01:16 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Any ideas???
Re: Tire Recommendation???? [Re: mopowers] #1348187
12/25/12 01:29 AM
12/25/12 01:29 AM
North Texas
3
360cuda Offline
360cuda  Offline
North Texas
I like these. I think they have the size that you need.
http://www.mickeythompsontires.com/street.php?item=SportsmanSR
Re: Tire Recommendation???? [Re: mopowers] #1348188
12/25/12 01:39 AM
12/25/12 01:39 AM
South East VA
Joel71 Offline
Joel71  Offline
South East VA
Any ideas???
What fits on the front? The 255/60-15s are 27" dia. Either a 235/60 or 245/60 on the front on a 7" wheel will give you some rake. I run 295/50-15s on the rear and 245/60-15s on the front of my Satellite. Outside Dia is almost the same. I have Firestones on the rear and Coopers on the front.
If you run a drag radial or street slick on the rear you won't get an exact matching tire for the front. If you want sonething small on the front it shouldn't be hard to find a radial that is around 25.5" to 26.5" dia that isn't very wide as long as the different tread pattern doesn't bother you. If you go bias ply there are plenty of front runner tires available.
Re: Tire Recommendation???? [Re: Joel71] #1348189
12/25/12 01:53 AM
12/25/12 01:53 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Any ideas???
I'm want to run a 205/65/15 on the front with a 255/60 on the back. Im hoping to find a decent front tire that will look okay with either a Radial TA rear, or possible a cooper cobra or MT drag radial. I just don't really like the weird looking ribs they put on these new passenger car tires. I'm trying to find something that has a smooth side. I just came across BFG Advantage TAs. They make a 205/65. Has anyone ever run them??
Re: Tire Recommendation???? [Re: mopowers] #1348190
12/25/12 07:00 AM
12/25/12 07:00 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
BFG TAs
I am truckless..
