Re: Rebuild or replace my 383? [Re: MidPenMopar] #1348066
12/10/12 07:07 PM
12/10/12 07:07 PM
Idaho
LaRoy Engines Offline
Idaho
For the west coast, you could also Google, LaRoy Engines. They are in Idaho. Check 'em out and maybe give them a call.
Re: Rebuild or replace my 383? [Re: MidPenMopar] #1348067
12/10/12 07:22 PM
12/10/12 07:22 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
In the end am looking for something that is set up for long life, durability, fuel economy over lots of horsepower.
It seems like a 383 would be perfect for you,if you are happy with the 383's performance. Sure a 440 or a 440 stroker will have more power, but the larger displacement will use more fuel. If you like the 383, keep it!
If you aren't going to abuse it, race it, or otherwise damage it, keeping the numbers matching engine in the car makes sense.
Re: Rebuild or replace my 383? [Re: CR8CRSHR] #1348068
12/11/12 12:38 AM
12/11/12 12:38 AM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I would first try and see if Mopar Engines West can fit you in. :
I dont have a year of spare time for them to get my engine done unfortunitly.
Re: Rebuild or replace my 383? [Re: MidPenMopar] #1348069
12/11/12 01:09 AM
12/11/12 01:09 AM
Outside
thedriver Offline
thedriver  Offline
Outside
Get a stroker off a 400 block, that way you can reuse your intake and headers and stuff.
1973 challenger
Dana. 4 speed. Low deck.
Re: Rebuild or replace my 383? [Re: thedriver] #1348070
12/11/12 01:56 PM
12/11/12 01:56 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
With Stu's garage bar, I think a "cosmetic restoration" on the numbers motor, would make for a cool addition -- a freshly cleaned and painted and dressed motor sitting on a stand in the corner of the bar area would look pretty cool.
**Photobucket sucks**
Re: Rebuild or replace my 383? [Re: 70Cuda383] #1348071
12/12/12 05:26 AM
12/12/12 05:26 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Stu, When I lived in the bay area in the mid 70s I raced roundy round in Vallejo and Petaluma. One of my sponsors was Jim, the owner of the machine shop at the NAPA in Petaluma Last I heard he was still there. The motors he built for us were great. We had 0 problems with them at all. Id give him a call to see if he is still there. I had a good friend in Antiock that built engines for a living. Id highly reccomend him if he was still alive. Is Vic Hubburd still in Hayward? There was also a good shop in Walnut Creek that used to build some bad azz engines..
I am truckless..
Re: Rebuild or replace my 383? [Re: 70Cuda383] #1348072
12/12/12 01:28 PM
12/12/12 01:28 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
These guys need to get off the stroker kick. he has no need for a stroker.
Let's see...
Fuel economy over hosepower.
Where does stroker fit into that statement?
Stick with a mild cammed 383 with 9.5:1 compression for the savings at the pump. It will make plenty of power and still return good mileage.
He needs torque at low to mid rpm and the 383 will do it without needing a long arm crank.
- Stu Harmon
Re: Rebuild or replace my 383? [Re: feets] #1348073
12/12/12 09:38 PM
12/12/12 09:38 PM
That's my thinking exactly!
Re: Rebuild or replace my 383? [Re: feets] #1348074
12/12/12 09:58 PM
12/12/12 09:58 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Let's see...
My buddy has a 512 in his charger and got 17 on the highway from OKC to Dallas with 3:55 gears and 28" tires.
Re: Rebuild or replace my 383? [Re: feets] #1348075
12/13/12 01:50 AM
12/13/12 01:50 AM
Outside
thedriver Offline
thedriver  Offline
Outside
Let's see...
Now yer speaking Eskimo. I didn't understand a damn word of that. EVERYONE needs a stroker!
1973 challenger
Re: Rebuild or replace my 383? [Re: 340SHORTY] #1348076
12/13/12 06:35 AM
12/13/12 06:35 AM
Petaluma, CA
JimDiesel Offline
JimDiesel  Offline
Petaluma, CA
The machine shop at the Petaluma Napa is closed.
The guy that took it over was terrible and went out of business. Pat was his name i think.
68 Road Runner
67 Coronet
Re: Rebuild or replace my 383? [Re: JimDiesel] #1348077
12/13/12 08:32 AM
12/13/12 08:32 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Do you know who Serge use? Im sure with all the iron he has there must be a machinist in his pocket..
I am truckless..
