Go pro mounts for under the car? #1347223
12/07/12 03:22 AM
12/07/12 03:22 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
You guys that have mounted a go pro or similar camera under your car to watch the suspension, what kind of mount did you use? Magnetic, clamp on, self adhesive, bolt on, etc? Any help would be appreciated. Thanks, Beep
Re: Go pro mounts for under the car? [Re: Bigbeep] #1347224
12/07/12 09:18 AM
12/07/12 09:18 AM
Ms.
Dartwizer Offline
Dartwizer  Offline
Ms.
I used this one from Panavise
Re: Go pro mounts for under the car? [Re: Dartwizer] #1347225
12/07/12 09:24 AM
12/07/12 09:24 AM
Ms.
Dartwizer Offline
Dartwizer  Offline
Ms.
Item # PV-727-04...Panaviseonline.com 1-800-675-2171
Re: Go pro mounts for under the car? [Re: Dartwizer] #1347226
12/07/12 12:56 PM
12/07/12 12:56 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I used the stick on mount, but made sure it was clean paint first...although the vid didn't turn out like I had hoped lol and sticky mount came off alot easier then I wanted it too...kinda made me uneasy about using it again under the car
Re: Go pro mounts for under the car? [Re: Bigbeep] #1347227
12/07/12 01:11 PM
12/07/12 01:11 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I believe the slot on the camera is .090 so just bend some aluminum,drill it for the mount bolt.
Re: Go pro mounts for under the car? [Re: Dartwizer] #1347228
12/07/12 01:23 PM
12/07/12 01:23 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have a few of those laying around the shop from cell phone days when they got mounted on the trans tunnel. lol Anyone remember the olden days?
I'm hoping for one for Xmas, actually I helped the wife pick it out, so I know we are getting one for Xmas and will take this mount home for it, thanks for the idea.
Re: Go pro mounts for under the car? [Re: Bigbeep] #1347229
12/07/12 02:24 PM
12/07/12 02:24 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
I use a Manfrotto super clamp. Google it, it is awesome and will not come off no matter what.It is made to clamp to round and square steel objects.Here is a vid on it.
http://youtu.be/9x_CnRPrA-0
Re: Go pro mounts for under the car? [Re: WheelsUp73] #1347230
12/09/12 09:20 PM
12/09/12 09:20 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Thanks guys. Keep them coming. the more options the better. Beep
Re: Go pro mounts for under the car? [Re: Bigbeep] #1347231
12/10/12 08:46 AM
12/10/12 08:46 AM
Long Island, NY
Cudafied Offline
Cudafied  Offline
Long Island, NY
Check out Part Of The Action's mount page Click here
To mount to a Gopro you would need the 1/4-20 tripod mount from Gopro.
Don't forget to type moparts for the coupon code to get discount...
Re: Go pro mounts for under the car? [Re: Cudafied] #1347232
12/10/12 09:44 AM
12/10/12 09:44 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Challanger I remember those.We had 2 guys get trained to install the pos phones.They either screwed them up or didnt want to do them.So I was lucky and got to install them.Was a pin but not hard work.Those stand can be adjusted to all kinds of positions.I had a few also.Tossed them as I hated installing phones.We probally had 10 or 20 laying around.Rocky
Chrysler Firepower
Re: Go pro mounts for under the car? [Re: WheelsUp73] #1347233
12/10/12 11:22 AM
12/10/12 11:22 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i want a mustach like that.
Re: Go pro mounts for under the car? [Re: bonefish] #1347234
12/11/12 02:49 AM
12/11/12 02:49 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Thanks guys. I purchased a little swivel mount that can be bolted to the car via a 1/4-20 bolt and then use the go pro adapter for a tripod. This should work underneath and on the roll bar mount I made years ago for my video camera. Thanks for the input. Beep
