Page 3 of 5 1 2 3 4 5
Re: Low Deck 400 Combos.... [Re: Cab_Burge] #1346817
12/11/12 12:19 AM
12/11/12 12:19 AM
Plant city fl
70Dart499 Offline OP
Plant city fl
OK, thanks for clearing that up with the Eddy RPM's my pistons are Flat top so I would be fine.
1970 Dart Drag Car
Re: Low Deck 400 Combos.... [Re: 70Dart499] #1346818
12/11/12 12:34 PM
12/11/12 12:34 PM
iowa
badplymouth67 Offline
iowa
The car is light motors nothing crazy dont know the weight only half dozen passes its chromoly and glass front doors trunk and lexan guess near 2500 lbs
Re: Low Deck 400 Combos.... [Re: badplymouth67] #1346819
12/11/12 01:25 PM
12/11/12 01:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Now THAT makes sense..........how fast would I be at that weight? Low 9`s high 8`s..........
Re: Low Deck 400 Combos.... [Re: Thumperdart] #1346820
12/11/12 02:09 PM
12/11/12 02:09 PM
ca
brownout Offline
brownout  Offline
ca
Thanks for the reply I figured it would be light but that still sounds like a good combo.
Thumperdart it would definitely fly just shaving a 100 pounds off makes a huge difference let alone 500 or so
I havent finished sorting out my low deck build.
499 with ported sr heads stock block filled with aluminum caps.
probably gonna be 13.5 compression on E-85
Just need to get a cam picked out for the combo.
I am hoping to go 9.60s on motor at about 3200 and caltracs.
Then I can use the fogger
Re: Low Deck 400 Combos.... [Re: brownout] #1346821
12/11/12 02:23 PM
12/11/12 02:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ll get there...............your combo sounds mean and the right roller cam should yield good results.
Re: Low Deck 400 Combos.... [Re: Thumperdart] #1346822
12/11/12 03:32 PM
12/11/12 03:32 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
440 Jim, has, i reckon one of the best running combos on this site, Cudadon, Dom and Prosport's old dartsport aren't far behind.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Low Deck 400 Combos.... [Re: deaks] #1346823
12/11/12 03:54 PM
12/11/12 03:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mick
Jim definately has it figured out and his car is very impressive................I hope to be in the 9.50`s sometime soon.
Re: Low Deck 400 Combos.... [Re: Thumperdart] #1346824
12/11/12 04:38 PM
12/11/12 04:38 PM
ca
brownout Offline
brownout  Offline
ca
I would have to agree with that.
Thumper that would be impressive if you can get it to run 9.50s
whats your car got underneath it cal tracs?
Yea i am thinking in the low 700 lift range with some 1.6 rockers for the cam should run alright
Re: Low Deck 400 Combos.... [Re: brownout] #1346825
12/11/12 04:48 PM
12/11/12 04:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m not saying it will 4 sure but after dialin in my carb and when I re-do the interior,take a few lbs. out and loosten up the ft. end it SHOULD go that fast............. Yes, cal-tracs and old 5-way Ranchos.............
Re: Low Deck 400 Combos.... [Re: Thumperdart] #1346826
12/11/12 04:50 PM
12/11/12 04:50 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would also have to say "Thumperdart" has one of the best running combo's here on Moparts. And I was really impressed with "ProSport's" old Dart Sport combo as it ran great for what it was. Ron
Re: Low Deck 400 Combos.... [Re: Cab_Burge] #1346827
12/11/12 05:11 PM
12/11/12 05:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Would that low deck block be of the aluminum KB variety
Cab yes it is a KB block, but it is a low deck one We have been 8.0's with it at 2900lbs a bunch. Never really sorted it out well for the all out stuff, needs more gear and looser converter. Throttle stop racing is what we do with it. 10.90 at 160 is fun I still run it all out once a year at the MATS. Dont even bother talking the stop off or switching converters anymore just turn off the timer and we still go .30's usually with the DA around 3500-4000' Makes good power and has been a pretty reliable piece, Checked the lash twice this year and adjusted nothing just put the covers back on it. Changed the oil three times and still have the same plugs in it. Gonna put in new plugs and valvesprings and ready for another year.
Re: Low Deck 400 Combos.... [Re: Al_Alguire] #1346828
12/11/12 05:48 PM
12/11/12 05:48 PM
Cab_Burge Online work
Cab_Burge  Online Work
I think I remember that piece on Jason dyno a long time ago when Chris had it, it shocked me on its power Thats what got me intereted in running B1 Now if the economy will pick up a little bit so I can spend some money on my toys
Re: Low Deck 400 Combos.... [Re: Cab_Burge] #1346829
12/12/12 04:43 AM
12/12/12 04:43 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
maxx block, -1's 512 279/50 solid roller 9.42 @ 142mph, 2950lb.
Re: Low Deck 400 Combos.... [Re: rebel] #1346830
12/12/12 08:49 AM
12/12/12 08:49 AM
gregsdart Offline
gregsdart  Offline
My old 499 combo- 4.15 stroke, 12.5 / 1 comp, bowl porting only on 440-1 heads, 319 flow at .600 Ultradyne roller with about 283/290/108 and 760 intake lift, single Domintor intake and fuel injected on alky. 3000 lb car ran 9.30 at 144 mph best.
Re: Low Deck 400 Combos.... [Re: gregsdart] #1346831
12/12/12 03:21 PM
12/12/12 03:21 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Guess I could post the Valiant combo. Was a stock 400low deck block, aluminum caps, 4.25 stroke, GRP rods, JE pistons at 13.5-1, B1 originals flowed 419 at .800", LSM roller 288/294 750/777 on a 113, cast single 4 and 1150 dominator. Powerdlide with 6200 stall and Dana 60 with a 4.30 gear, MT 29.5x10.5 tire. Car weighed 3470 went 9.04 at 149.
Re: Low Deck 400 Combos.... [Re: Al_Alguire] #1346832
12/12/12 04:27 PM
12/12/12 04:27 PM
Mo.
racerx Offline
racerx  Offline
Mo.
At what weight?
Re: Low Deck 400 Combos.... [Re: racerx] #1346833
12/12/12 04:33 PM
12/12/12 04:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Car weighed 3470 with my fat rear in it..All steel full interior, mild steel cage, full glass and working radio
Re: Low Deck 400 Combos.... [Re: Al_Alguire] #1346834
12/12/12 06:01 PM
12/12/12 06:01 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Ok......i didn't see it in your last replie .....But Thax any-way
Re: Low Deck 400 Combos.... [Re: 383man] #1346835
12/14/12 02:13 PM
12/14/12 02:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thank you and Prosport really motivated me to build a small motor and see what my dumb azz could do with it and so far so good. I expect to see high 9.50`s soon w/just some weight removal and the timing fix and carb tuning Cab turned me onto..............
Re: Low Deck 400 Combos.... [Re: Thumperdart] #1346836
12/14/12 02:47 PM
12/14/12 02:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Dom you really need to bring that thing to the MATS this year. True Street Challenge is calling your name. Need to contact whichever magazine does this deal. Would love to see you come and take that deal.
