Re: Low Deck 400 Combos....
[Re: 70Dart499]
#1346778
12/06/12 01:05 PM
12/06/12 01:05 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
I have built alot of them: 1.) 451 B1-BS head tunnel ram 525hp to the rear wheels 2.) 469 B1-BS head tunnel ram ?HP (NEW) 3.) 498 B1-BS head Indy Tunnel Ram (Max Wedge Port) 867HP @ 6500 rpm will make more power at higher RPM 7500rpm should be around 920HP 4.) 511 Indy-1 Head 690HP to the rear wheel
[Re: 70Dart499]
#1346779
12/06/12 01:10 PM
12/06/12 01:10 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Mine is a 512 Indy -1 heads/intake Dominator 1050 6.10 1/8 mile 9.59 1/4 @ 139.60 arround 3400 pounds I have to update sig.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: 70Dart499]
#1346780
12/06/12 01:10 PM
12/06/12 01:10 PM
Thumperdart
State of confusion
Here`s mine; 400 bored 4.377 JE pistons at 12.1.1 comp. THUMPER ported rpm`s w/a 2.19 in. and standard ex. Isky solid roller .680-.660 w 275-280 dur. @ .050 stock offset ground 413 crank at 3.900 1050 dommy and a vic jr intake 2" Hooker fenderwell headersand 3 1/2" bullet muffs 727 trans built by Darrell Parks 8 3/4 rear w/4.11 Richmond gears w/stock caps and backbraced.......
[Re: Biginchmopar]
#1346783
12/06/12 01:34 PM
12/06/12 01:34 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
mine is a 470 Indy Ez heads comp solid roller 620 gross lift. 1150 dominator, 3200lb car with me, typically 60 foot is 1.40 1/8th 6.30 1/4 10.0s to 10teens @ 132 to 134mph
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: 70Dart499]
#1346784
12/06/12 03:42 PM
12/06/12 03:42 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
Question, at what point do you need to fill the block with hard block?
NEVER fill the blcok Sonic test it first before boring it, if it will be .140 or thicker after boring use it OP, I have several 400 low deck motors, 400 with 440 crank,906 heads, single four barrel,hydraulic cam, made a little 500 HP on CA pump swill, 512 with ported big valve 906 heads and a six pak, solid roller made 612 HP at 5600 and 544 Ft. Lbs at 4500 on CA pump swill years ago, smae motor with a 4.300 stroke crank, 518 C.I., CNC ported heads and the same cam and intake made 718 HP and 745 Ft.Lbs on a Happy Studka engine dyno. My 3450 lb. car ran 10.34 at 128.6 MPH on Oregon pump gas throgh the mufflers. Same short block with M.W. intake port size Indy SR and a single 1050 Domintor on a Indy 400-3 intake manifold made 727 HP and 710 Ft. Lbs on a DTS dyno at 4300 Ft. above sea level, it has ran 9.94 at 134.8 MPH in my car with the air cleaner and muffs on The latest motor is a thick main web 400 cold weather block(Thanks AndyF )505 C.I. 4.350 bore with a 4.250 stroke Ohio Crankshaft CO. crank, Eddy RPM heads CNC ported, Mopar M1 4500 intake and a 1050 Dominator, Bullet solid roller cam with Harland Sharp 1.65 ratio rockers, it makes 687 HP and 650 Ft lbs, not ran in a car yet Too many motors and not enough cars
[Re: jamesc]
#1346786
12/06/12 06:26 PM
12/06/12 06:26 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
We used to fill all blocks years ago, when all you have is a stock block you have to. We used concrete grout back then.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: 70Dart499]
#1346787
12/08/12 09:29 AM
12/08/12 09:29 AM
Posts: 16,928 NC
440Jim
NC
Who else here is running a Low Deck 400 combo?
Never been on a dyno, but it's run 6.80's in my 3200 pound Dart,
Mine has not been on the dyno either, but it has run 5.75 in my 3250 lb Dart. More typical weather 5.85 1/8, 9.28 1/4
400 block, 4.375" bore 4.250" Callies crankshaft, 511 CID 6.535" H-beam rods, 2.2" (Chevy) rod journals 13.5 CR Comp Cams MM305S solid lifter, flat tappet cam 279/287 at 0.050", .650"/.630" lift (published) Indy 440-1 heads, milled to 68cc, some porting Indy 400-3 intake, single four, 4500 pattern 2-1/8" x 32" headers
Block filled to 2.6" from the deck Aluminum main caps
[Re: 440Jim]
#1346788
12/08/12 12:37 PM
12/08/12 12:37 PM
Posts: 976 ontario canada
mac56
ontario canada
400 block concrete to the top stock caps with girdle 4.150 crank 6.535 bme rods diamond pistons 15-1 B-1 orginals .760 lift tunnel ram and 2 toilets alcohol Hasn't been on the dyno but it isn't very fast. It takes me 15 seconds to go 300 feet
[Re: mac56]
#1346789
12/08/12 01:02 PM
12/08/12 01:02 PM
Posts: 2,449 nc
earthmover
nc
well here goes haven't ran it yet or put it in the chassis..trying to finish the chassis now. 400 low deck stroked to 451 hard block to bottom of water pump holes eagle 3.75 crank and h-beam rods je piston dome tops 400 intake with 4500 top going to run a toilet set up on alky 13.1 comp 10qt pan with k/b oil pump duel line 440-1 heads with 2.25 valve t&d rockers cam motion roller headers will be step and made at home 727 trans 8" turbo action 5600 verta 430 gear in a ford 9' CAR SHOULD BE 24/2500LBS ready to race with driver I hope
[Re: 70Dart499]
#1346793
12/08/12 04:16 PM
12/08/12 04:16 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The old 451 11:1 compression dished ROSS pistons (pump gas) with B1-B/S heads, and a solid street roller, only 251/251@ 0.050", 0.614" lift, M1 intake, Holly HP 1,000 cfm carb and 2" hooker headers. Full 3" TTI exhaust with superflow mufflers. Only Chassis dyno 457 HP, 446 TQ at rear wheels. The 499 is 12.4:1 compression flat top ICON (440 source kit) pistons, Edelbrock Victor MW heads, 264/264 @ 0.050" comp HXL solid roller, 0.720" lift, 4150 Indy single plane, same carb and headers as above (for now.) Chassis dyno 560 HP, torque was below my converter, one reading shows 505 TQ, another 630 ft/lbs? This is when I was having issues with the heads. I plan to flow the heads, and maybe pick a larger cam and use bigger carb.
[Re: mac56]
#1346794
12/08/12 07:13 PM
12/08/12 07:13 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
Looks cool Mac! That's the first time I've seen that picture.
