Page 1 of 5 1 2 3 4 5
Low Deck 400 Combos.... #1346777
12/06/12 12:18 PM
12/06/12 12:18 PM
Plant city fl
70Dart499 Offline OP
Plant city fl
Who else here is running a Low Deck 400 combo? I would like to hear what combo you are using, and what horsepower you are making. My combo is a 499, 906 heads, purple cam, old Holley streeet dominator manifold, 850 Demon carb, eagle rotating assembly. Never been on a dyno, but it's run 6.80's in my 3200 pound Dart, I'm sure it could run quicker but it's a bracket car so I don't lean on it. Let's hear your combos.
1970 Dart Drag Car
Re: Low Deck 400 Combos.... [Re: 70Dart499] #1346778
12/06/12 01:05 PM
12/06/12 01:05 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I have built alot of them:
1.) 451 B1-BS head tunnel ram 525hp to the rear wheels
2.) 469 B1-BS head tunnel ram ?HP (NEW)
3.) 498 B1-BS head Indy Tunnel Ram (Max Wedge Port) 867HP @ 6500 rpm will make more power at higher RPM 7500rpm should be around 920HP
4.) 511 Indy-1 Head 690HP to the rear wheel
Re: Low Deck 400 Combos.... [Re: 70Dart499] #1346779
12/06/12 01:10 PM
12/06/12 01:10 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Mine is a 512 Indy -1 heads/intake Dominator 1050 6.10 1/8 mile 9.59 1/4 @ 139.60 arround 3400 pounds I have to update sig.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Low Deck 400 Combos.... [Re: 70Dart499] #1346780
12/06/12 01:10 PM
12/06/12 01:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Here`s mine;
400 bored 4.377
JE pistons at 12.1.1 comp.
THUMPER ported rpm`s w/a 2.19 in. and standard ex.
Isky solid roller .680-.660 w 275-280 dur. @ .050
stock offset ground 413 crank at 3.900
1050 dommy and a vic jr intake
2" Hooker fenderwell headersand 3 1/2" bullet muffs
727 trans built by Darrell Parks
8 3/4 rear w/4.11 Richmond gears w/stock caps and backbraced.......
Re: Low Deck 400 Combos.... [Re: Biginchmopar] #1346781
12/06/12 01:17 PM
12/06/12 01:17 PM
Carson City, Nevada
Carson City, Nevada
I always wanted to put together a 526CID low deck motor:
4.375" bore
4.375" stoke
6.535" rod
Original B1's
I bet it would rip!
Re: Low Deck 400 Combos.... [Re: Biginchmopar] #1346782
12/06/12 01:22 PM
12/06/12 01:22 PM
Plant city fl
Plant city fl
Question, at what point do you need to fill the block with hard block?
1970 Dart Drag Car
Re: Low Deck 400 Combos.... [Re: Biginchmopar] #1346783
12/06/12 01:34 PM
12/06/12 01:34 PM
fresno ca
mikeysmopars Offline
fresno ca
mine is a 470 Indy Ez heads comp solid roller 620 gross lift.
1150 dominator, 3200lb car with me, typically 60 foot is 1.40 1/8th 6.30 1/4 10.0s to 10teens @ 132 to 134mph
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Low Deck 400 Combos.... [Re: 70Dart499] #1346784
12/06/12 03:42 PM
12/06/12 03:42 PM
NEVER fill the blcok Sonic test it first before boring it, if it will be .140 or thicker after boring use it
OP, I have several 400 low deck motors, 400 with 440 crank,906 heads, single four barrel,hydraulic cam, made a little 500 HP on CA pump swill, 512 with ported big valve 906 heads and a six pak, solid roller made 612 HP at 5600 and 544 Ft. Lbs at 4500 on CA pump swill years ago, smae motor with a 4.300 stroke crank, 518 C.I., CNC ported heads and the same cam and intake made 718 HP and 745 Ft.Lbs on a Happy Studka engine dyno. My 3450 lb. car ran 10.34 at 128.6 MPH on Oregon pump gas throgh the mufflers. Same short block with M.W. intake port size Indy SR and a single 1050 Domintor on a Indy 400-3 intake manifold made 727 HP and 710 Ft. Lbs on a DTS dyno at 4300 Ft. above sea level, it has ran 9.94 at 134.8 MPH in my car with the air cleaner and muffs on The latest motor is a thick main web 400 cold weather block(Thanks AndyF )505 C.I. 4.350 bore with a 4.250 stroke Ohio Crankshaft CO. crank, Eddy RPM heads CNC ported, Mopar M1 4500 intake and a 1050 Dominator, Bullet solid roller cam with Harland Sharp 1.65 ratio rockers, it makes 687 HP and 650 Ft lbs, not ran in a car yet Too many motors and not enough cars
Re: Low Deck 400 Combos.... [Re: Cab_Burge] #1346785
12/06/12 04:15 PM
12/06/12 04:15 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
there's nothing wrong with using grout in a stock cylinder block if it's done properly. i've seen stock blocks with split bores that probably wouldn't have split had they been grouted. looking around i just saw mention of a product called Embeco 885 that's supposed to be good stuff.
Re: Low Deck 400 Combos.... [Re: jamesc] #1346786
12/06/12 06:26 PM
12/06/12 06:26 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
We used to fill all blocks years ago, when all you have is a stock block you have to. We used concrete grout back then.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Low Deck 400 Combos.... [Re: 70Dart499] #1346787
12/08/12 09:29 AM
12/08/12 09:29 AM
NC
440Jim Offline
440Jim  Offline
NC
Mine has not been on the dyno either, but it has run 5.75 in my 3250 lb Dart. More typical weather 5.85 1/8, 9.28 1/4
400 block, 4.375" bore
4.250" Callies crankshaft, 511 CID
6.535" H-beam rods, 2.2" (Chevy) rod journals
13.5 CR
Comp Cams MM305S solid lifter, flat tappet cam 279/287 at 0.050", .650"/.630" lift (published)
Indy 440-1 heads, milled to 68cc, some porting
Indy 400-3 intake, single four, 4500 pattern
2-1/8" x 32" headers
Block filled to 2.6" from the deck
Aluminum main caps
Re: Low Deck 400 Combos.... [Re: 440Jim] #1346788
12/08/12 12:37 PM
12/08/12 12:37 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
400 block concrete to the top
stock caps with girdle
4.150 crank
6.535 bme rods
diamond pistons 15-1
B-1 orginals
.760 lift
tunnel ram and 2 toilets
alcohol
Hasn't been on the dyno but it isn't very fast. It takes me 15 seconds to go 300 feet
Re: Low Deck 400 Combos.... [Re: mac56] #1346789
12/08/12 01:02 PM
12/08/12 01:02 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
well here goes haven't ran it yet or put it in the chassis..trying to finish the chassis now.
400 low deck stroked to 451
hard block to bottom of water pump holes
eagle 3.75 crank and h-beam rods
je piston dome tops
400 intake with 4500 top
going to run a toilet set up on alky
13.1 comp
10qt pan with k/b oil pump duel line
440-1 heads with 2.25 valve
t&d rockers
cam motion roller
headers will be step and made at home
727 trans 8" turbo action 5600 verta
430 gear in a ford 9'
CAR SHOULD BE 24/2500LBS ready to race with driver I hope
Re: Low Deck 400 Combos.... [Re: earthmover] #1346790
12/08/12 01:08 PM
12/08/12 01:08 PM
okla.
sam64 Offline
sam64  Offline
okla.
511,12.5 comp.,indy sr's,.620 solid ft,been 10.14@132 in my 3000lb 65 coronet.have only made 6 passes so far.
Re: Low Deck 400 Combos.... [Re: sam64] #1346791
12/08/12 02:46 PM
12/08/12 02:46 PM
s.e. michigan
top8x7b Offline
top8x7b  Offline
s.e. michigan
451 400 block 440 crank wiseco pistons 440 source rods stealth heads comp cams flat tappet 607 cam m1 single plan intake 850 carb 10.50s @128 mph in a 3200 Abody
Re: Low Deck 400 Combos.... [Re: top8x7b] #1346792
12/08/12 03:33 PM
12/08/12 03:33 PM
Hamiltucky
RBDuster Offline
RBDuster  Offline
Hamiltucky
470 here. crank and rods are eagle with diamond pistons. Indy SR's with mild port 75cc chamber comp cam 661 lift with a 276 duration at 50. Car has been a best of 5.81 at 120 in the 1/8th. Car weighs 2510 with driver.
Re: Low Deck 400 Combos.... [Re: 70Dart499] #1346793
12/08/12 04:16 PM
12/08/12 04:16 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The old 451 11:1 compression dished ROSS pistons (pump gas) with B1-B/S heads, and a solid street roller, only 251/251@ 0.050", 0.614" lift, M1 intake, Holly HP 1,000 cfm carb and 2" hooker headers. Full 3" TTI exhaust with superflow mufflers. Only Chassis dyno 457 HP, 446 TQ at rear wheels.
The 499 is 12.4:1 compression flat top ICON (440 source kit) pistons, Edelbrock Victor MW heads, 264/264 @ 0.050" comp HXL solid roller, 0.720" lift, 4150 Indy single plane, same carb and headers as above (for now.) Chassis dyno 560 HP, torque was below my converter, one reading shows 505 TQ, another 630 ft/lbs? This is when I was having issues with the heads. I plan to flow the heads, and maybe pick a larger cam and use bigger carb.
Re: Low Deck 400 Combos.... [Re: mac56] #1346794
12/08/12 07:13 PM
12/08/12 07:13 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
4.150 crank
6.535 bme rods
B-1 orginals
.760 lift
alcohol
Looks cool Mac! That's the first time I've seen that picture.
Re: Low Deck 400 Combos.... [Re: camastomcat] #1346795
12/08/12 07:18 PM
12/08/12 07:18 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
4.150 crank
6.535 bme rods
B-1 orginals
.760 lift
alcohol
LOOK AT HIS AVATAR
Re: Low Deck 400 Combos.... [Re: CSK] #1346796
12/08/12 08:09 PM
12/08/12 08:09 PM
mi usa
O
old yeller Offline
old yeller  Offline
O
mi usa
Are we just talking about factory Low decks?
