Ebay 413 Pistons #1346263
12/05/12 12:42 AM
12/05/12 12:42 AM
Shelby, Ohio
JeffL Offline OP
JeffL  Offline OP
Shelby, Ohio
Has anybody here purchased These
Are they any good?
Thanks!
Re: Ebay 413 Pistons [Re: JeffL] #1346264
12/05/12 01:25 AM
12/05/12 01:25 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I have heard good reports on them B U T they are low compression pistons. I have got a call-out to Sealed Power doing these pistons in a higher compression ratio ... like doing the pin location .030 and .060 lower in the piston. I just have to find how many sets have to be ordered in-order to have them run like that.
Re: Ebay 413 Pistons [Re: JeffL] #1346265
12/05/12 11:04 AM
12/05/12 11:04 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
This guy sells kits call him and ask what compression height his pistons are
http://www.ebay.com/itm/Chrysler-V-8-413...=item4d0264663d
he puts togeather 413 stroker kits too
http://www.ebay.com/itm/CHRYSLER-413-426...=item35c097783c
Re: Ebay 413 Pistons [Re: Dodgem] #1346266
12/05/12 12:48 PM
12/05/12 12:48 PM
dogdays Offline
dogdays  Offline
Compression height of 2.015" will build some pretty good compression.
BUT: Weight of 1010 grams? I assume that's with pin, but still really really heavy. I think for a couple of hundred more you could get a new custom forging that weighed no more than 800 grams with pin.
I have no reason to doubt the quality of the pistons, but they are pretty high priced for what you get.
Do a search for 413 stroker with my username going back the maximum and you will get an idea for another approach. Otherwise, find out who on the board is a dealer for your favorite brand of high performance pistons and contact him to gt a price for some real pistons.
R.
Re: Ebay 413 Pistons [Re: JeffL] #1346267
12/05/12 01:04 PM
12/05/12 01:04 PM
dogdays Offline
dogdays  Offline
With a flat top and 2.015" compression height they are not low compression pistons.
Two things:
1. They are expensive for a cast piston with rings.
2. They weigh (assuming with the pin) 1010 grams, that's a little over 2.2 lb each. You should be able to find a lightweight forging for a couple of hundred more that should weigh no more than 800 grams with pin. There are piston dealers on this board.
Oh, one other thing: Do a search on 413 stroker and my username to find another way to go with that block. I believe I've been talking about this idea for three years.
R.
Re: Ebay 413 Pistons [Re: dogdays] #1346268
12/05/12 07:58 PM
12/05/12 07:58 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
PRETTY GOOD ? ...I would agree. But what I would like is something like the 6-pack piston is ... 2.06.
In my motorhome/towing combo .. you could open-up the chambers in the "goofy-heads" very nicely(to cut down the comp-ratio). Then this would get you the squish/quench so many people desire. Now in a HP application .... say with a closed-chambered alum head .. it would get the compression up there nicely ... GET YOU that good squish/quench .. but you would for-sure have to fly-cut the pistons for a decent cam-lift.
Pricing ? ... a little over 400$ complete ? ... that is one-half to one-third the price of the custom forged stuff.
