Re: 5spd options?
[Re: CFster]
#1346005
12/04/12 06:39 PM
12/04/12 06:39 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I would really love to have a Passon 5-speed but I already installed a Richmond 5-speed before his ever came out. A Richmond is a great transmission if you don't mind cutting your floor and torsion bar crossmember it took me a weekend to cut and fab the crossmember,cut and box my torsion bar crossmember,and make a custom trans tunnel Buy the Passon unit and just bolt it in much easier and I believe a better transmission than the Richmond IMHO Just talking from first hand experience here Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: 5spd options?
[Re: fourgearsavoy]
#1346006
12/04/12 08:00 PM
12/04/12 08:00 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Hp power levels? intended use of the car? big block or small block? If you're building a mild small block, the truck NV3500 may be a cheap option for you. you can pick one up for a couple hundred bucks out of the junk yard and bolts right up to the small block engines. I was pushing an estimated 350hp/400 ft lbs of torque through mine and it was ok for the 4,000 miles I put on it. (My truck dyno'd at 285 hp and 325 tq at the wheels) that said, they ARE only rated for 350 ft lbs by the factory, and I'm in the middle of swapping in a viper T56 transmission so I can do more with my motor down the line and not worry about gernading the trans. the NV3500 kinda bulky though, not sure it'll bolt in without mods to the sheet metal. but it is CHEAP! (you can even buy a remanufactured one for about $1,000 without a core) There's a Toyota trans I believe designated R154? that some guys have used. apparently if you take the AX-15 bell housing off a V6 Dakota truck it'll bolt to R154 and the 3.9 V6s use the same small block bell pattern as every other small block. If you're making serious power and want a TKO-600, I know a guy that can set you up with a full kit for less than $5,000 and doesn't use a single Keisler part. AND, it uses an SFI certified blowproof bell
**Photobucket sucks**
Re: 5spd options?
[Re: CFster]
#1346009
12/04/12 10:42 PM
12/04/12 10:42 PM
fourgearsavoy
Rittman Ohio
So you just want a "5-speed" or would you consider one of Jamie's OD gear sets for a 4-speed case I have done a few of these conversions and they are very nice Here is the thread about the 5-speed https://board.moparts.org/ubbthreads/show...e=0#Post6330693As for Jamie's 5 speed I think it's worth the money for ease of use and superior engineering If I need a release bearing or a pilot bearing I don't have to order one special from Passon(although thats who I deal with anyway)I can get one from many other sources. Gus
Re: 5spd options?
[Re: fourgearsavoy]
#1346010
12/05/12 09:33 AM
12/05/12 09:33 AM
70Cuda383
Marysville, O-H-I-O
Plus since you don't want to cut or modify your floor, that pretty much kills all of your 5 speed options, other than Jamie's unit, because my understanding of it is that he got it all to fit inside a standard 4-spd box.
with a big block and not wanting to do any metal modification, then your 5-spd options are going to be extremely limited.
The gear vendors are nice from what I hear, I've never used one myself...but they are also not cheap, and their OD is only a .78:1
What's the OD ratio in the passion unit? the TKO has a .82 or a .64OD. that .64 allowed me to turn only 2400 rpm on the highway with 29" tires, and 4.56 gears in the axle.
for reference, my current truck had an NV3500, with a .73 OD and with 26.7" tires, 3.92 gears, I was turning nearly 3,000 rpm at 70mph
Re: 5spd options?
[Re: 70VERT]
#1346011
12/05/12 10:06 AM
12/05/12 10:06 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Call Jamie Passon at Passon Performance his 5 speed is bullet proof and looks great also--I have one behind my 440 and I couldn't be more pleased
Its out? As in, you can finally buy and install one now...???
This is the way to go if you can afford it.
Re: 5spd options?
[Re: CFster]
#1346013
12/05/12 10:48 AM
12/05/12 10:48 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Just got a response email from Jamie Passon. My price would be $4495 and they're not released for production yet.
Everybody has been talking about this trans but you can't buy one. I'll tell you what, I don't want to be one of the first to own one either, especially with all the talk of case porosity in the other thread. What other problems will crop up once they start getting used in the real world.
A GV unit might be the way to go. It has the benefit of 8 effective gear ratios and is nearly indestructible.
The case porosity issue was quickly resolved according to what I read, and is a non-issue at this point.
The GV gear splitter unit doesn't have enough of an OD ratio to make it appealing to most. Plus, it seems like quite a challenge to shift it up and down while trying to bang gears on a four speed, especially when you have to shift it back down before shifting into the next higher gear...1st low, click-up, first high, click-down, second low, click-up second high....etc etc
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: 5spd options?
[Re: jbc426]
#1346014
12/05/12 11:00 AM
12/05/12 11:00 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if your 383 is fairly mild with a wide torque curve, your best options will probably be to try find an iron case A833OD---
gear ratios are:
3.09/1.67/1/.73 and work nice for highway gearing with 3.23-3.55 gears and 26-28" tall tires.
Re: 5spd options?
[Re: jbc426]
#1346015
12/05/12 11:05 AM
12/05/12 11:05 AM
Posts: 533 East Windsor, CT
CFster
super street
super street
East Windsor, CT
Yeah, there is that...
Re: 5spd options?
[Re: CFster]
#1346018
12/05/12 02:40 PM
12/05/12 02:40 PM
patrick
Grand Haven, MI
How do some people have these Passons???
the Passon OD gearset for the 4 speed has been around for years. the new 5 speeds that are out are probably pre-production test pieces.
Re: 5spd options?
[Re: CFster]
#1346019
12/05/12 03:53 PM
12/05/12 03:53 PM
Posts: 75,059 U.S.S.A.
JohnRR
U.S.S.A.
There are a few people that are testing them for Passon .
