low band apply question #1345934
12/04/12 01:37 PM
12/04/12 01:37 PM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
I'm using a transbrake vb with low band apply and a bolt in sprag. Does that mean i'm safe with a stock front drum or is the billet front drum still mandatory?
Re: low band apply question [Re: mopar dave] #1345935
12/04/12 01:55 PM
12/04/12 01:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Which bolt in sprag is it , a Coan or A+A or just a stock replacement ? If it's a stock replacement
Re: low band apply question [Re: JohnRR] #1345936
12/04/12 02:19 PM
12/04/12 02:19 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I asked this question in a few different threads not too long ago...do a search on my posts for anything transmission related in the last couple months and you'll see some stuff.
Basically I concluded that some said you would be safe, while others said you wouldn't. From the searching I did, the aftermarket super sprag with I believe 16 rollers was adapted from C6 transmissions, and it is impossible for it to roll over...not sure how true that is, but if its correct, then maybe a billet drum isn't necessary (although definitely an extra precaution that can't hurt anything but the wallet).
The final question always came down to- how much do you like your feet? LOL
Re: low band apply question [Re: mshred] #1345937
12/04/12 02:55 PM
12/04/12 02:55 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I believe I would Error on the side of caution, then you can sleep well at night.
Re: low band apply question [Re: dartman366] #1345938
12/04/12 03:15 PM
12/04/12 03:15 PM
Mt Morris Michigan
Mt Morris Michigan
Stock replacement bolt in. I'' try searching. Thanks
Re: low band apply question [Re: mopar dave] #1345939
12/04/12 03:34 PM
12/04/12 03:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Either get the Coan or A+A or get a drum.
All the stock replacement bolt in does is stop the outer race from spinning in the case, it does nothing to stop the rollers from rolling over should you overpower the band.
Re: low band apply question [Re: JohnRR] #1345940
12/04/12 04:41 PM
12/04/12 04:41 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
727 or 904...
727's are the exploders.
904 I wouldn't be too concerned
Re: low band apply question [Re: RobX4406] #1345941
12/05/12 01:16 AM
12/05/12 01:16 AM
Mt Morris Michigan
Mt Morris Michigan
727
Re: low band apply question [Re: mopar dave] #1345942
12/05/12 01:31 AM
12/05/12 01:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm still one of the OLD guys(with both feet) that
still runs a stock drum with non low apply.. if you
have to get out of it in LOW gear, you shift before
you get back in it.... its called dont do stupid sh1t...
MANY MANY of us ran these without blowing then up
but you cant do the stupid sh1t.... the low band apply
will help you ALOT (it takes load of the sprag)
Re: low band apply question [Re: MR_P_BODY] #1345943
12/05/12 12:09 PM
12/05/12 12:09 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
not if they're assembled and operated by someone that's competent.
the cause and cure for these failures is well known as is the reason they occur.
sure there are plenty of horror stories and pictures floating around the net, like guys putting a stock 727 behind a blown hemi and it fails. do you think the person that doesn't know better then to put a stock 727 behind a blown hemi also knows how to properly operate the transmission?
the 727 has withstood a lot of abuse over the years and yes in some cases has failed but calling them exploders is a bit of a stretch
for many applications the 727 is a perfectly fine transmission
as for the OP to get the correct answer you need to describe your application
Re: low band apply question [Re: jamesc] #1345944
12/05/12 03:58 PM
12/05/12 03:58 PM
Mt Morris Michigan
Mt Morris Michigan
600hp/3300# mostly street,but tnt 2 or 3 times a season. want to use my transbrake next season just finding peace of mind with the trans and axles. with launch about 4400-4500 and if i lose a driveshaft or u joint i want to be safe. would the rear band apply prevent an explosion if the d shaft failed on launch?
Re: low band apply question [Re: mopar dave] #1345945
12/05/12 04:08 PM
12/05/12 04:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Just run it , you'll be fine ....
