How the factory painted 69 runner hood stripes?
#1345724
12/04/12 10:26 AM
12/04/12 10:26 AM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Just for correct research on how the factory originally painted the wide hood stripes. Not the type of paint but when they actually did it. I had a discusion with a good friend who says he remembers seeing a tech article that says they painted the stripe first then mask it off and painted the body color. I said from looking at original cars it looked like the stripe was painted on after body color. But I didn't know for sure. Anyone have any documentation that shows what they did at the factory????? Here's a pic of an original 69 hemi runner, 4sp, 4:10 car.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
Re: How the factory painted 69 runner hood stripes?
[Re: A12]
#1345726
12/04/12 01:15 PM
12/04/12 01:15 PM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
I have been told by several people that the stripes were indeed painted before the body color.
68 Charger R/T 440 auto
[Re: wesgtx440]
#1345727
12/04/12 01:36 PM
12/04/12 01:36 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Yep, me too.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1345731
12/04/12 09:21 PM
12/04/12 09:21 PM
wesgtx440
Dayton, WA
Found a tech. article in Mopar Action magazine, Oct. 2012 issue, pg.16 that talks about the hood blackout treatment on a 69 RR. Reasons stated: The basic paint was acrylic enamel, and uncured enamel can be softened by lacquer, which the Organisol paint was. Hood and fenders were masked and sprayed with the black lacquer. Then the black was masked off and the body color applied. End of the article reads, OE resto will always be "black first"
[Re: wesgtx440]
#1345733
12/04/12 10:48 PM
12/04/12 10:48 PM
Posts: 21,526 N.E. OHIO, USA
A12
N.E. OHIO, USA
How long to cure and why doesn't this bulletin warn about repainting too soon? I'm sure the "L" in "DDL" means lacquer but they only say to reduce with Acrylic Thinner? (no mention of lacquer?)
What's been said makes sense but the bulletin makes no mention or warning about un-cured Acrylic Enamel and painting too soon with Organosol
[Re: RUNCHARGER]
#1345736
12/05/12 01:25 AM
12/05/12 01:25 AM
Posts: 1,179 Canada
demon
Canada
That's why I believe that could be true, but I don't have a survivor handy to check out. The lower paint treatment on a 69 X or a Coronet 500 would have to have been done that way as well if this is the way it was. They must have used lacquer primer as well....
Sheldon
Chrysler did not use laqcuer primer. They used epoxy primer only at that time. Most Chrysler factories sprayed the bare body (after the chemical dip, latex primer dip process) with red oxide epoxy, then green-grey epoxy. This was then baked and then wet sanded before spraying it with Enamel and again baking it.
[Re: wesgtx440]
#1345738
12/05/12 01:30 AM
12/05/12 01:30 AM
Posts: 1,179 Canada
demon
Canada
that is completely wrong for the 69 Road Runner hood blackout. There is a lot of misinformation in magazines. While Mopar action is the best for tech, their body related articles are usually amatuer and crude at best. They even suggested using silicone as a body sealer in one article! Haha!
[Re: demon]
#1345739
12/05/12 02:04 AM
12/05/12 02:04 AM
DPelletier
correct or not, at least I'm not going crazy! Dave
1974 'Cuda
[Re: MOPARMIKE69]
#1345740
12/05/12 03:52 AM
12/05/12 03:52 AM
A12
N.E. OHIO, USA
Could you tell if there is hood stripe paint in between the fender and the hood gap or how the paint line is in those areas. Seems to me I have some photos of the F8 green Hemi road runner survivor in those areas and there is F8 paint under the hood stripe. How would they have done the cowl area if they did the stripe first? Just asking.
Interesting question
Yes there is black over spray in the gaps, that is also leading me to think they were painted after color.
The Hemi road runner underhood taken back in 2004 with hood stripe overspray what seems to be the whole lenght of the inner fender
[Re: A12]
#1345741
12/05/12 10:27 AM
12/05/12 10:27 AM
MOPARMIKE69
Nashville, TN
Ok I received an e-mail back from my friend. Here is what he said. "I spoke with David Patik of Performance Car Graphics (his site had the images & measurements of the Hood Blackout for 69 RR/GTX). I remembered that he had told me about the Blackout Organosol lacquer painting sequence. I called him today about the price of the Front Air Spoiler for the Super Bird. While on the phone I asked about the Hood Blackout and he said that it was painted first on all cars that had Organosol Lacquer, then the Enamel body paint was applied as (according to him) the lacquer wouldn't stick to enamel. He referred me to the "Lynch Road Article - Order of Assembly", which outlines this." Somewhere I have this factory bulletin. I will post it when I find it. So if anyone else has it please post. My main question with this theory is why are there not masking lines in side the hood area, that for sure has overspray on original cars????? The only explanation I can think of would be you would have to paint the engine compartment, then paint the stripes, let them dry, close the hood, mask the stripes off, and paint the outside of the car? I would just like to know for sure which it was, not for argument sake, but just for knowledge. Where's Paul Jacobs when you need him!!!!!!
[Re: MOPARMIKE69]
#1345742
12/05/12 12:21 PM
12/05/12 12:21 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
Just an FYI. I had an original paint B7 70 Road Runner in the shop not too long ago and without a doubt those stripes were put on after the body was sprayed.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: MOPARMIKE69]
#1345743
12/05/12 12:51 PM
12/05/12 12:51 PM
MOPARMIKE69
Nashville, TN
I found my paper work actually compiled by David. However it is all about the building of the Superbird at Lynch Road. It doesn't say anything about hood stripes. So there must be another bulletin about just the regular assembly. I do not have it if there is another one. I will keep searching for this bulletin. Since several of you have original cars that show body color under the faded stripes, examples of overspray, and edges showing the stripes painted after color, to be sure I need to read the factory document. BUT..... I am still thinking they were painted after color.. it makes too much sense, plus the cars I have seen.
