Re: 4 speed shifter/knob combinations
[Re: AlexP]
#134568
10/10/08 11:42 AM
10/10/08 11:42 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
get the correct handle and if necessary drill the shifter for the handle
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: AlexP]
#134569
10/10/08 04:36 PM
10/10/08 04:36 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I believe the '68 B body mechanism is the same as the later OD trans mechanism so you should be able to use the correct stick for your B body.
Check for the number 6353 stamped in the reverse (long) lever.
[Re: AlexP]
#134575
10/22/08 10:56 PM
10/22/08 10:56 PM
Posts: 4,150 lewiston, ID
cornucopia
lewiston, ID
here's what I got in my '69 coronet: the stick is actually the factory stick out of a 1980 chevy malibu, 3-speed car that I used to own. it has the EXACT same bends as a '69 mopar stick but is quite a bit shorter overall. I really like it.
