4 speed shifter/knob combinations #134567
10/09/08 10:55 PM
10/09/08 10:55 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I'm trying to decide what shifter handle/knob to run.
I've got a non-console bench 68 Roadrunner, a Hurst push-in shifter body off of a late 70's OD truck.
What options do I have ? I know I'm going to run a Hurst white 4-speed ball for sure...
I've seen the straight Hurst S/C handle, and the curved handle for the bench also. Some pictures would really help my selection. I'm not going to do a pistol grip on this car.
Thanks...
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 4 speed shifter/knob combinations [Re: AlexP] #134568
10/10/08 11:42 AM
10/10/08 11:42 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
get the correct handle and if necessary drill the shifter for the handle
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 4 speed shifter/knob combinations [Re: AlexP] #134569
10/10/08 04:36 PM
10/10/08 04:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I believe the '68 B body mechanism is the same as the later OD trans mechanism so you should be able to use the correct stick for your B body.
Check for the number 6353 stamped in the reverse (long) lever.
Re: 4 speed shifter/knob combinations [Re: AlexP] #134570
10/10/08 05:45 PM
10/10/08 05:45 PM
Arizona
anmracing Offline
anmracing  Offline
Arizona
Here are some pix of the shifter we are using. We had to bend it a little due to hitting the knuckles on the dash..... Now it works just fine!!!!
Re: 4 speed shifter/knob combinations [Re: anmracing] #134571
10/11/08 01:40 AM
10/11/08 01:40 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I suggest a curved, bench seat shifter stick. Nothing fancy, just one bend, but it needs to clear the bench when in 2nd and 4th gears with the seat pushed forward:
Inland 4-speed shifter stick in my '77 Aspen above.
Re: 4 speed shifter/knob combinations [Re: anmracing] #134572
10/21/08 09:39 PM
10/21/08 09:39 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Re: 4 speed shifter/knob combinations [Re: AlexP] #134573
10/22/08 02:51 PM
10/22/08 02:51 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Re: 4 speed shifter/knob combinations [Re: AlexP] #134574
10/22/08 04:45 PM
10/22/08 04:45 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Here's a
This setup works pretty good for me
Darren
Re: 4 speed shifter/knob combinations [Re: AlexP] #134575
10/22/08 10:56 PM
10/22/08 10:56 PM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
here's what I got in my '69 coronet:
the stick is actually the factory stick out of a 1980 chevy malibu, 3-speed car that I used to own. it has the EXACT same bends as a '69 mopar stick but is quite a bit shorter overall. I really like it.
