Engine Oil Cooler #1345599
12/03/12 10:32 PM
12/03/12 10:32 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
Will oil drainback be a problem on start-up if the cooler is mounted in a location higher than the oil pan?
Re: Engine Oil Cooler [Re: TrWaters] #1345600
12/03/12 10:52 PM
12/03/12 10:52 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
VERY possible ... but a cooler on a drag car ?
Re: Engine Oil Cooler [Re: dOoC] #1345601
12/03/12 11:25 PM
12/03/12 11:25 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Don't ,,MAYBE you can play here awhile.!!
If you like drag racing, support your local track.
Re: Engine Oil Cooler [Re: CHAPPER] #1345602
12/03/12 11:51 PM
12/03/12 11:51 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I have a thermostatically controlled cooler mounted behind the grill on my B-body Hemi. Same virtually instant pressure as before.
Re: Engine Oil Cooler [Re: Lee446] #1345603
12/04/12 06:15 PM
12/04/12 06:15 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
Not a dedicated drag car, and cooler will be mounted about valve cover height.
Re: Engine Oil Cooler [Re: dOoC] #1345604
12/04/12 09:43 PM
12/04/12 09:43 PM
Az
Crizila Offline
Crizila  Offline
Az
What makes you think you need one??
Fastest 300
Re: Engine Oil Cooler [Re: Crizila] #1345605
12/04/12 09:49 PM
12/04/12 09:49 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
Any answers to my actual question will be appreciated, which was not "do I need an oil cooler?".
Will there be a drainback problem with using a high mounted oil cooler? Thanks.
Re: Engine Oil Cooler [Re: TrWaters] #1345606
12/04/12 10:39 PM
12/04/12 10:39 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
where is the to cooler line coming from?
Re: Engine Oil Cooler [Re: rickraw] #1345607
12/04/12 11:01 PM
12/04/12 11:01 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I thought I did !!??
Re: Engine Oil Cooler [Re: TrWaters] #1345608
12/04/12 11:25 PM
12/04/12 11:25 PM
It really dpends on how you plumb it, if it is a BB and you are going to use a remote oil filter mount and use a T fitting to the cooler and another line back into the line going to the block the oil pump may stop any drain back, if not plumbing it that way you might want to install a anti drainback check valve
Re: Engine Oil Cooler [Re: TrWaters] #1345609
12/04/12 11:34 PM
12/04/12 11:34 PM
Az
Crizila Offline
Crizila  Offline
Az
Sorry. The answer to your question ( IMO )is "yes". I will add, although you didn't ask, if you are not running oil temps in excess of 250 degrees for long periods of time, you don't need an oil cooler - IMO.
Fastest 300
Re: Engine Oil Cooler [Re: Crizila] #1345610
12/05/12 12:52 AM
12/05/12 12:52 AM
IN
ahy Offline
ahy  Offline
IN
Oil coolers are usually mounted in front of the Rad... above oil pan height almost always. I don't see how "drainback" would be an (added) problem. The rest of the engine is above oil pan height also.
Re: Engine Oil Cooler [Re: ahy] #1345611
12/05/12 12:11 PM
12/05/12 12:11 PM
Az
Crizila Offline
Crizila  Offline
Az
In my experience, they all drain back over time, check valves or not - including the factory installed units. It just amounts to a longer time before oil pressure comes up. Is that bad? Well, it aint good, and a poor trade off if you don't need to go there. Obviously, stock motors with lower compression and tighter clearances would suffer less than the other way around. My tow vehicle has one. Good application there, especially where I live - plus it doesn't sit for long periods of time between start ups. My race car ( with a filled block ) does not - and doesn't need one. If the OP KNOWS he is running outside (hotter) what his oil temp range should be, he needs one. Otherwise, he don't. IMO,in many cases they are installed unnecessarily. I was going to install one on my race car, but decided to install an oil temp gauge first, just to see where I was at. Good move on my part ( for a change ). I was well within the oil temp parameters for the oil I am using.
Fastest 300
Re: Engine Oil Cooler [Re: Crizila] #1345612
12/05/12 12:14 PM
12/05/12 12:14 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
I would do everything I could to prevent oil starvation on startup since that's where a ton of wear occurs.
Has anyone ever seen or used those devices that stores up some oil pressure, so that when you start the car, you can release that into the system for a shot of oil? I always wanted to use one of those.
Having said that, on any oil cooler, it's a great idea to use a thermostat. Same on a trans cooler (at least for street duty)
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Engine Oil Cooler [Re: TrWaters] #1345613
12/05/12 12:23 PM
12/05/12 12:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put a trap in the line... have it go up higher so
it doesnt drain back as much... being that the filter
is on the pressure side of the system its either going
to drain back to the pump or towards the oil galley...
most(if not all) filters have a anti drain back valve
Re: Engine Oil Cooler [Re: TrWaters] #1345614
12/11/12 02:55 PM
12/11/12 02:55 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
For what it's worth, the factory mopar oil coolers were mounted in front of the radiator, at about center-block level. They are fed from the upper oil gallery, and where it came out of the block, there's a factory mopar checkvalve for anti-drain back. As long as you do something like that, you're at least as good as factory.
If you want that part number, I can get it for you. can probably still find them. I'm sure they are around as typical race parts, too.
Re: Engine Oil Cooler [Re: VincentVega] #1345615
12/11/12 05:37 PM
12/11/12 05:37 PM
scratchnfotraction Offline
I think mopar did more than just that for the stock oil cooler package.
my stock oil cooler from the 88 cop car was set up this way. full pressure feed to the cooler from the oil sender hole on the SB and back to the hollow fuel pump bolt to oil t-chain and return oil to the pan.
had timed oiling to the rockers on #2 & #4 cam journal.
#1 cam bearing had full time oiling groove to #1 main bearing.
#1,2,3,4,5 main bearings were full groove for better supply to oil rod bearings. standerd volume oil pump.
no check valve on mine , and I have found the bearings speced like this on at least 3 cop engines I have torn down. longevity was the goal on a stock oil cooler package.
the anti drainback valve on the oil filter should hold most of the prime on the pump side.IMO.
Re: Engine Oil Cooler [Re: scratchnfotraction] #1345616
12/11/12 06:29 PM
12/11/12 06:29 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
I'm looking at the check valve in the parts catalog for R/W body. Both big block and 360 uses it. The preceding page has H/F/N/G oil cooler w/ E58 small block engine, and you're right, no check valve. The implementation is basically the same except for that, fed via the upper gallery in the back, to a return in the fuel pump bolt.
If anyone wants it, the checkvalve PN is 2264514 (an old number).
A search comes up with this description: "Disc, oil pressure relief valve." At this point I'm wondering if it uses a stiff opening spring and closes off flow in the event of low pressure (to prevent starvation). Mine is around somewhere, I wish I could find it to take a look. I would love to know exactly what they were doing with it. I'd almost bet money it's just a simple check valve, but it's hard to find descriptions of minutiae like this
Re: Engine Oil Cooler [Re: VincentVega] #1345617
12/11/12 07:14 PM
12/11/12 07:14 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
I have been using a water oil cooler for the last 8 years. It's mounted in front of the radiator. Never a problem. With a Milodon HV oil pump my oil pressure is almost instant. I have a short filled block. Without a cooler my oil temp would hit 320.
Re: Engine Oil Cooler [Re: Big B] #1345618
12/12/12 11:19 AM
12/12/12 11:19 AM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Welp, when I'm wrong, I'm wrong. And that's often!
The E58 on the Diplomat body does use the oil "check valve", it's just mounted on the cooler instead of at the back of the block like on the B body. I must have been really tired yesterday to miss that!
