How much driveshaft clearance to tailhousing? #1345529
12/03/12 06:27 PM
12/03/12 06:27 PM
Mansfield, Tx
Jacob Pitt Offline OP
Mansfield, Tx
Was under the car the other day after I put the new gears in and re-adjusted the ladder bars. On the ground there isn't much room from the end of the driveshaft yoke to the end of the transmission tailshaft. How much clearance do I actually need?
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: How much driveshaft clearance to tailhousing? [Re: Jacob Pitt] #1345530
12/03/12 06:36 PM
12/03/12 06:36 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Old rule of thumb was +- 2" with springs. I think with ladder bar or 4 link, you could get by with less than this.
Have a Merry Christmas
Old Geezer Racing
Re: How much driveshaft clearance to tailhousing? [Re: Jacob Pitt] #1345531
12/03/12 06:44 PM
12/03/12 06:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
3/4"
Re: How much driveshaft clearance to tailhousing? [Re: MR_P_BODY] #1345532
12/03/12 07:11 PM
12/03/12 07:11 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
If the tailshaft seal has a boot, 1/2" of slip yoke showing is plenty.
Mopar to the bone!!!
Re: How much driveshaft clearance to tailhousing? [Re: 72Swinger] #1345533
12/03/12 11:08 PM
12/03/12 11:08 PM
NC
440Jim Offline
440Jim  Offline
NC
My 2-cents.
With a 4-link suspension, you can easily get by with 1" travel, and Mr.P may be right with 3/4". That includes compressing the dust boot if your transmission seal has one.
Re: How much driveshaft clearance to tailhousing? [Re: 440Jim] #1345534
12/04/12 12:11 AM
12/04/12 12:11 AM
Mansfield, Tx
Mansfield, Tx
Yes it has a dust boot on it and the yoke is compressing it some at rest. When I got it back-halved the builder put in a bunch of pinion angle and I guess he did it to pull the driveshaft away from the transmission. I have corrected it and noticed how close they are now. I will measure it to make sure it has at least 3/4". Thanks for the help.
14x Track Champ
Re: How much driveshaft clearance to tailhousing? [Re: Jacob Pitt] #1345535
12/04/12 12:36 AM
12/04/12 12:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont even mind if it compresses the dust boot a
little but I also put some grease on the edge of
the yoke where it touches... still on the original
seal/boot
EDIT
Just as long as I get the 3/4"(thats at curb height)
Re: How much driveshaft clearance to tailhousing? [Re: Jacob Pitt] #1345536
12/04/12 12:52 AM
12/04/12 12:52 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Chally, witch dust boot do you have. The 2.5" or the .5" dust boot.
Re: How much driveshaft clearance to tailhousing? [Re: Sport440] #1345537
12/04/12 12:20 PM
12/04/12 12:20 PM
Mansfield, Tx
Mansfield, Tx
The 2.5" dust boot.
14x Track Champ
Re: How much driveshaft clearance to tailhousing? [Re: Jacob Pitt] #1345538
12/04/12 12:40 PM
12/04/12 12:40 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Take the driveshaft loose from the rear and see how much further it will slide into the tailshaft housing from where it is now, or measure from the cup to the yoke fully bottomed in the trans, sounds like you should be ok.
Re: How much driveshaft clearance to tailhousing? [Re: Jacob Pitt] #1345539
12/04/12 01:07 PM
12/04/12 01:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine`s about 3/4-1" w/caltracs and never an issue.......YET!
Re: How much driveshaft clearance to tailhousing? [Re: Jacob Pitt] #1345540
12/04/12 09:39 PM
12/04/12 09:39 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The 2.5" dust boot.
Then you have Plenty of clearence. You stated at rest your yoke does compress the boot a little. So you have just under 2.5" clearence the way I measure. I measure from the yoke bottoming out into the tailshaft housing. With the 1/2" boot I like to see 3/4" to 1" clearence at rest.
IMO, on a race car you want as much yoke engagement as possible without it bottoming out on a launch.
Your just under 2.5" clearence is working for you and has with others. I wouldnt feel the need to get a new shaft. But I do like to see more engaugement then you have for a race car.
Re: How much driveshaft clearance to tailhousing? [Re: Jacob Pitt] #1345541
12/04/12 11:00 PM
12/04/12 11:00 PM
I measure the spline length in the trans. yoke, not all of them are the same I use half of that as my target length, I.E. 3.0 inches of spline length inside I slide the yoke in all the way and pull it out 1.5 inches for the center to center of the Ujoints on the driveshaft as my desired installed length with the weight of the car on the wheels or on jackstands under the rear axle and under the lower control arms out as far as I can get them to simulate race conditions
