How much driveshaft clearance to tailhousing?
#1345529
12/03/12 06:27 PM
12/03/12 06:27 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Was under the car the other day after I put the new gears in and re-adjusted the ladder bars. On the ground there isn't much room from the end of the driveshaft yoke to the end of the transmission tailshaft. How much clearance do I actually need?
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: How much driveshaft clearance to tailhousing?
[Re: Jacob Pitt]
#1345530
12/03/12 06:36 PM
12/03/12 06:36 PM
Posts: 1,505 TN
SCATPACK 1
TN
Old rule of thumb was +- 2" with springs. I think with ladder bar or 4 link, you could get by with less than this. Have a Merry Christmas
Old Geezer Racing
[Re: MR_P_BODY]
#1345532
12/03/12 07:11 PM
12/03/12 07:11 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
If the tailshaft seal has a boot, 1/2" of slip yoke showing is plenty.
Mopar to the bone!!!
[Re: 440Jim]
#1345534
12/04/12 12:11 AM
12/04/12 12:11 AM
Jacob Pitt
Mansfield, Tx
Yes it has a dust boot on it and the yoke is compressing it some at rest. When I got it back-halved the builder put in a bunch of pinion angle and I guess he did it to pull the driveshaft away from the transmission. I have corrected it and noticed how close they are now. I will measure it to make sure it has at least 3/4". Thanks for the help.
[Re: Jacob Pitt]
#1345538
12/04/12 12:40 PM
12/04/12 12:40 PM
dartman366
Mt. Vernon, Ohio
Take the driveshaft loose from the rear and see how much further it will slide into the tailshaft housing from where it is now, or measure from the cup to the yoke fully bottomed in the trans, sounds like you should be ok.
[Re: Jacob Pitt]
#1345540
12/04/12 09:39 PM
12/04/12 09:39 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
The 2.5" dust boot.
Then you have Plenty of clearence. You stated at rest your yoke does compress the boot a little. So you have just under 2.5" clearence the way I measure. I measure from the yoke bottoming out into the tailshaft housing. With the 1/2" boot I like to see 3/4" to 1" clearence at rest.
IMO, on a race car you want as much yoke engagement as possible without it bottoming out on a launch.
Your just under 2.5" clearence is working for you and has with others. I wouldnt feel the need to get a new shaft. But I do like to see more engaugement then you have for a race car.
