Any way of telling cast, from chrome & from moly rings? #1345506
12/03/12 04:57 PM
12/03/12 04:57 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
If you have some rings with no box, how can you tell if they are cast, chrome or moly rings???
Thanks!
Re: Any way of telling cast, from chrome & from moly rings? [Re: domingo] #1345507
12/03/12 05:08 PM
12/03/12 05:08 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The wear edge of a cast ring will be dark in color as same as the rest of the ring,a moly ring will be dark grey in color and the wear edge will be a bright silver.A moly filled ring will dark with a silver wear edge.Most all chrome rings will be a chrome appearence.
Re: Any way of telling cast, from chrome & from moly rings? [Re: B G Racing] #1345508
12/03/12 05:28 PM
12/03/12 05:28 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I compared this one to a set of new moly rings I had and it looks similar....dark ring and the wear edge is silver in color, however since this engine was assembled (though never run) the silver has darkened a bit.
Would you say its moly?
Thanks!
Re: Any way of telling cast, from chrome & from moly rings? [Re: domingo] #1345509
12/03/12 05:29 PM
12/03/12 05:29 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
nuther shot
Re: Any way of telling cast, from chrome & from moly rings? [Re: domingo] #1345510
12/03/12 05:48 PM
12/03/12 05:48 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The silver or lighter one looks to be moly filled(topring),the dark one with the yellow paint visiable is cast(2nd ring).
Re: Any way of telling cast, from chrome & from moly rings? [Re: B G Racing] #1345511
12/03/12 06:55 PM
12/03/12 06:55 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
great! Now I will hone my cyls with 400 grit stone for the moly rings.
