Lifter preload question #1345132
12/02/12 08:12 PM
12/02/12 08:12 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
I'm replacing intake and valve cover gaskets and want to check my lifter preload while I'm this far in. It's a rb with hydraulic cam/ lifter w adjustable rockers. My question (probably dumb) is should I back off all the adjusters at first or just the cylinder I'm working on?
As I said, probably dumb but I'm having a brain seize...
Re: Lifter preload question [Re: slowpoke] #1345133
12/02/12 09:03 PM
12/02/12 09:03 PM
If your going to remove the intake valley pan find a piece of wire that is around .030 diameter to use to check the preload between the lifter cup and the wire retaining clip I like and use between 1/4 and 3/8 turn preload from zero clearances on the adjuster srew , I use my fingers to move the pushrod up and down while adjusting the adjusters to get zero preload
I just finished a new motor with hydraulic lifters, I brought #1 piston to top dead center on the firing stroke and set both lifters, I rotated the crank 90 degrees clockwise and did # 8 and then #4 and so on It is probally better to do the adjustment with the motor warmed up like you drive it
Re: Lifter preload question [Re: slowpoke] #1345134
12/02/12 11:16 PM
12/02/12 11:16 PM
Put the timing marks at TDC #1 compression & make a magic marker ink mark on the side of a small steel scale (ruler) & set it across the valve cover rails & slide it over quickly before the ink dries being careful to avoid the springs & let it touch either #1 pushrod to make a very small mark on it then loosen the adjuster till the lifter cup is up all the way & repeat making another mark then measure the distance between your two marks.
Re: Lifter preload question [Re: Cab_Burge] #1345135
12/02/12 11:48 PM
12/02/12 11:48 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
...If your going to remove the intake valley pan find a piece of wire that is around .030 diameter to use to check the preload between the lifter cup and the wire retaining clip...
A spark plug wire gauge works good for this.
Re: Lifter preload question [Re: 6PakBee] #1345136
12/03/12 07:04 PM
12/03/12 07:04 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Thanks for the responses guys!!!
