Manual steering gear box question.............??????? #1344841
12/02/12 02:53 AM
12/02/12 02:53 AM
State of confusion
Thumperdart Offline OP
State of confusion
Curious as to what grease/lube you guys put in the manual boxes. Mine was rebuilt years ago but is starting to bind up a bit and seems low on lube.............thankxxx............
Re: Manual steering gear box question.............??????? [Re: Thumperdart] #1344842
12/02/12 03:19 AM
12/02/12 03:19 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think a lot of guys pump them full of grease since the oil just leaks out.
Mopar to the bone!!!
Re: Manual steering gear box question.............??????? [Re: 72Swinger] #1344843
12/02/12 03:23 AM
12/02/12 03:23 AM
State of confusion
State of confusion
That`s what I origionally did but it has been slightly leaking over the years so maybe some synthetic grease............. thankxxx
Re: Manual steering gear box question.............??????? [Re: 72Swinger] #1344844
12/02/12 03:24 AM
12/02/12 03:24 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Use 90 wt in mine, but they never leaked. Grease would be the proper choice if they do.
-Daty
Re: Manual steering gear box question.............??????? [Re: Daty Rogers] #1344845
12/02/12 03:28 AM
12/02/12 03:28 AM
State of confusion
State of confusion
I`ll mess w/it tomorrow just to make sure that`s the binding tight wheel I`ve been feeling last couple times out cruisin around.........
Re: Manual steering gear box question.............??????? [Re: Thumperdart] #1344846
12/02/12 09:30 AM
12/02/12 09:30 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Grease and 90 wt gear oil heated out blend together.
Re: Manual steering gear box question.............??????? [Re: moparpollack] #1344847
12/02/12 11:11 AM
12/02/12 11:11 AM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
any lube with moly added will help reduce resistance
Re: Manual steering gear box question.............??????? [Re: moparpollack] #1344848
12/02/12 12:39 PM
12/02/12 12:39 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Re: Manual steering gear box question.............??????? [Re: dodger mope] #1344849
12/02/12 12:41 PM
12/02/12 12:41 PM
State of confusion
State of confusion
Thankxx........... Looking back, I think I added some thick azz grease to try and keep it from leaking when it got hot..........
Re: Manual steering gear box question.............??????? [Re: Thumperdart] #1344850
12/02/12 01:14 PM
12/02/12 01:14 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Put a Zerk grease fitting in it. Be carefull not to over fill it.
Re: Manual steering gear box question.............??????? [Re: MattW] #1344851
12/02/12 10:04 PM
12/02/12 10:04 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Fix the leaking seal/worn sector shaft.
Re: Manual steering gear box question.............??????? [Re: TrWaters] #1344852
12/03/12 04:41 PM
12/03/12 04:41 PM
State of confusion
State of confusion
I don`t mess w/that stuff generally but may have to..........I`m going to go check it out now and see what`s up.
