68gtx paint color? #1343691
11/30/12 10:25 PM
11/30/12 10:25 PM
68gtx Offline OP
68gtx  Offline OP
I am restoring a 1968 GTX matching motor, matching trans, no build sheet or fender tag. Not worried about those things because it does have a matching numbers 440 and an 18 spline hemi trans which is also matching numbers. Here is the problem, we want to put this car back to original color but we can't tell what color it is! Here are a couple pictures of areas of the car, one looks turquoise the other looks blue. The turquoise is from the cowl and the blue is from the trunk.....anyone have any ideas?! I know the colors can be deceiving but the color in the trunk does seem to have a blue green hue to it, the one on the cowl is definatley turquoise in my opinion.
Re: 68gtx paint color? [Re: 68gtx] #1343692
11/30/12 10:32 PM
11/30/12 10:32 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 68gtx paint color? [Re: Alaskan_TA] #1343693
11/30/12 10:43 PM
11/30/12 10:43 PM
68gtx Offline OP
68gtx  Offline OP
Sorry my attachments didn't work, I will try again.
Re: 68gtx paint color? [Re: 68gtx] #1343694
12/01/12 02:21 AM
12/01/12 02:21 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Looks like UU1 to me. Light Metallic Blue.
Re: 68gtx paint color? [Re: topside] #1343695
12/01/12 04:00 AM
12/01/12 04:00 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I was getting dizzy
Re: 68gtx paint color? [Re: 6bblgt] #1343696
12/01/12 04:02 AM
12/01/12 04:02 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
What color is the interior? Blue interiored '68 b-bodies had "U" upper door frame paint.
Re: 68gtx paint color? [Re: 6bblgt] #1343697
12/01/12 04:05 AM
12/01/12 04:05 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
It looks like paint code U - "frost blue metallic" in Plymouth speak.
Here's a couple "U" painted Charger pics - some original paint spots.
Re: 68gtx paint color? [Re: 6bblgt] #1343698
12/01/12 04:11 AM
12/01/12 04:11 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Paint code K - "mist turquoise metallic" was a c-body ONLY color in '68.
Here's a Charger with original tired & worn L - "surf turquoise metallic" (again Plymouth speak).
Re: 68gtx paint color? [Re: 6bblgt] #1343699
12/01/12 06:51 AM
12/01/12 06:51 AM
68gtx Offline OP
68gtx  Offline OP
I think it is U code as well. But that color on the cowl looks turquoise. Might just be 45 year old faded paint. As my wife would pick a blue color and paint it!!!!! LOL!!! She a chevy fan. I know I still married her!!!! What was I thinking!!!!Thanks Larry J
Re: 68gtx paint color? [Re: 68gtx] #1343700
12/01/12 06:55 AM
12/01/12 06:55 AM
68gtx Offline OP
68gtx  Offline OP
It has black interior and black on the interior doors. And has one original door that has not been repainted. Thanks Larry J
Re: 68gtx paint color? [Re: 68gtx] #1343701
12/01/12 07:15 AM
12/01/12 07:15 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
See if you can chip some undercoating off, if it has it, to reveal the color underneath.
Re: 68gtx paint color? [Re: 68KillerBee] #1343702
12/01/12 07:34 AM
12/01/12 07:34 AM
68gtx Offline OP
68gtx  Offline OP
The teal or turquoise color from the cowl is what is under the under coating?? The car has had 1 repaint. Someone painted orange and did not strip it so I have the blue color in the jambs and trunk. Which looks a little darker than U code almost looks like B5 blue? Then that teal color under the undercoating. The jambs and trunk are original color. Motor is date coded 8-1. So I think Q code is out. But it does look closer to B5 than mist or frost blue in person. I will try to send some pics of the jambs. We would like to paint it back to its original color. I know there is no build sheet or fender tag,but it does have a matching motor and trans. You don't realize how important those little fender plates are until you start restoring!!!!!!!!!! Thanks Larry J
Re: 68gtx paint color? [Re: 68gtx] #1343703
12/01/12 10:24 AM
12/01/12 10:24 AM
68gtx Offline OP
68gtx  Offline OP
U code seems to be too light. I took some samples from online. I know thats not perfect science. But the B5 blue sample is almost perfect. What 68 plymouth color is close to B5 blue any??? I am going to pull something with the original color on it and take it to the local paint supply and see what they come up with.Thanks Larry J
Re: 68gtx paint color? [Re: 68gtx] #1343704
12/01/12 01:06 PM
12/01/12 01:06 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
Didnt use B5 in 68.QQ1 and its different,fresh example.
Re: 68gtx paint color? [Re: wannadrag] #1343705
12/01/12 01:12 PM
12/01/12 01:12 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Only 4 blues for '68 B-bodies:
UU1 - light
QQ1 - medium
EE1 - dark
999 - Corporate (aka "Petty"), on a batch of RRs.
Here's QQ1 in sunlight
Re: 68gtx paint color? [Re: wannadrag] #1343706
12/01/12 01:15 PM
12/01/12 01:15 PM
68gtx Offline OP
68gtx  Offline OP
I realize B5 came in 69 I think? Just seams like it has a slight bit of bluish green then other places light silver blue?? I think its U code. Would the under coating change the color over time or preserve it?? Because when you take a little under coating it is without a doubt teal turquoise in color?? Thanks for all the response. Larry J
Re: 68gtx paint color? [Re: 68gtx] #1343707
12/01/12 01:25 PM
12/01/12 01:25 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
Behind the wiper motor or master cyl is sometimes a good spot to look.
Re: 68gtx paint color? [Re: wannadrag] #1343708
12/01/12 01:50 PM
12/01/12 01:50 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you plan to remove the windshield (A new gasket is a good idea) the paint under the old gasket should be pristine...
Re: 68gtx paint color? [Re: wannadrag] #1343709
12/01/12 01:57 PM
12/01/12 01:57 PM
68gtx Offline OP
68gtx  Offline OP
Been there its teal. As I said everything from the door jambs forward that was under coated is absolutely teal turquoise in color. But the jambs trunk behind the seat some of it looks like B5 and some u code. I know those areas have never been painted. The rear tail light panel has to be replaced. So I think I will cut 1 of the support braces off and take to the paint supply store and see if we can narrow it down. Thanks Larry J
Re: 68gtx paint color? [Re: 68gtx] #1343710
12/01/12 02:17 PM
12/01/12 02:17 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Paint codes for 1968 were a single letter.
I bet all you guys that refer to paint codes like "UU1" say "dual field" alternator, too.
Down to just a blue car now.
