cleaining the inside of a 8.75 housing #1343452
11/30/12 01:41 PM
11/30/12 01:41 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I've got a 8.75 house that is all rusty and scaly on the inside. I can wire wheel the outside, but what the easiest way to clean out the inside to get it ready for assembly??? The local machine shop wants $40 to hot tank it. Will hot tanking it get rid of the rust and scale? Would it be worth the $40??? Can I pre-treat it with something to make sure to comes out clean????
Any ideas????
Re: cleaining the inside of a 8.75 housing [Re: mopowers] #1343453
11/30/12 04:52 PM
11/30/12 04:52 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
You could soak it with one of the rust converter products (phosphoric acid solution), but you'd have to plug the axle tube ends carefully, and keep sloshing/turning. Could take a while now that it's colder, too.
That much Ospho (or similar) would probably cost more than the $40. I'd just have it tanked.
Re: cleaining the inside of a 8.75 housing [Re: DrCharles] #1343454
11/30/12 05:24 PM
11/30/12 05:24 PM
Easiest way to go is just to have it acid dipped.
Re: cleaining the inside of a 8.75 housing [Re: ] #1343455
11/30/12 05:57 PM
11/30/12 05:57 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Acid dipped in California?
I'd pressure wash all the grease and oil off of it in and out and then sand blast it in and out. Then paint the outside and after it's dry I would pressure wash the inside to remove any sand. Then your ready for assembly and gear oil.
Or look for another housing...
Re: cleaining the inside of a 8.75 housing [Re: Challenger 1] #1343456
11/30/12 06:22 PM
11/30/12 06:22 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I'm pretty sure the petroleum based hot tanks that repair shops of yesteryear had are banned here. (elsewhere too?)
All the repair shops here have aqueous based hot washing tanks with high pressure sprayers that revolve around the part.
But I think there are special places in California that dip car bodies to remove paint and rust. So I'd think those places would do a rear end housing. Maybe they advertise in Drive Magazine??
I know they acid dip for removal of metal (chemical machining) still here in So Cal. I think it's used in the aircraft industry. Don't know if they would do a project like this though.
Re: cleaining the inside of a 8.75 housing [Re: mopowers] #1343457
11/30/12 06:50 PM
11/30/12 06:50 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I would think finding another housing would be easier and cheaper !!!
Re: cleaining the inside of a 8.75 housing [Re: Stanton] #1343458
11/30/12 07:03 PM
11/30/12 07:03 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
that's a perfect job for vinegar based rust removal. there are several posts on moparts describing the process it takes a lot of vinegar but it is cheap
Re: cleaining the inside of a 8.75 housing [Re: ScottSmith_Harms] #1343459
11/30/12 07:41 PM
11/30/12 07:41 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Maybe shot blast the inside of the tubes?
Hot tanks out here don't do much if anything to rust.
The vinegar would work too. Get a piece of 5-8" diameter PVC, large enough to stand the tube up and do it one tube at a time. That way you don't have a huge vat of the stuff and it also minimizes the amount of vinegar/lemon juice/salt that you need.
Re: cleaining the inside of a 8.75 housing [Re: mopowers] #1343460
11/30/12 08:03 PM
11/30/12 08:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Just glass bead or sandblast the interior then wash it out thoroughly with soap and water then blow dry.
I've done it many times and then painted the interior with Rustoleum Red Primer or Glyptol.
Re: cleaining the inside of a 8.75 housing [Re: John_Kunkel] #1343461
11/30/12 08:56 PM
11/30/12 08:56 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I found a local blasting facility that is sand blasting the inside for $40. Heck of a deal if you ask me!!!
Re: cleaining the inside of a 8.75 housing [Re: mopowers] #1343462
11/30/12 10:13 PM
11/30/12 10:13 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
I've got a 8.75 house that is all rusty and scaly on the inside. I can wire wheel the outside, but what the easiest way to clean out the inside to get it ready for assembly??? The local machine shop wants $40 to hot tank it. Any ideas????
I would hot tank! 40$ is money well spent. Napa did this manifold and it came out looking like new
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: cleaining the inside of a 8.75 housing [Re: 19cuda73] #1343463
11/30/12 10:15 PM
11/30/12 10:15 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
After It cost $25
1972 Corvette
Re: cleaining the inside of a 8.75 housing [Re: 19cuda73] #1343464
11/30/12 11:17 PM
11/30/12 11:17 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That is without ANY follow up bead blasting? Nice!
What sort of cleaning tank did they use to get that?
Can they still do the old fashioned caustic chemical hot dip like the old days in other states??
Re: cleaining the inside of a 8.75 housing [Re: autoxcuda] #1343465
12/01/12 01:12 AM
12/01/12 01:12 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Just got a local quote about 2 weeks ago to chemical dip and powder coat a hsg $175-$200
Re: cleaining the inside of a 8.75 housing [Re: 19cuda73] #1343466
12/01/12 04:15 PM
12/01/12 04:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Are you sure it was tanked? Looks more like cooked and shot beaded.
Re: cleaining the inside of a 8.75 housing [Re: John_Kunkel] #1343467
12/01/12 09:56 PM
12/01/12 09:56 PM
Cincinnati, Ohio
Cincinnati, Ohio
No a real castic hot tank will make them look like new, even eat the rust off. I used to use one quite a bit.
Most imoportant thing to remember on sb is to grind off the rivets holding the cover on the bottem of a stock intake to get it clean and clean the plate separately in the hot tank.
Re: cleaining the inside of a 8.75 housing [Re: Challenger 1] #1343468
12/02/12 02:18 PM
12/02/12 02:18 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
That is true when I took in the 340 intake they took off the bottom pan hot tanked it and reinstalled it. The unit came out looking just like the big block piece. In Washington they must still be able to use the real deal solution not sure what it is but it works sweet. I have a whole slou of valve covers I need to take in next.
1972 Corvette
Re: cleaining the inside of a 8.75 housing [Re: 19cuda73] #1343469
12/02/12 09:35 PM
12/02/12 09:35 PM
The old caustic hot tank solutions need to have the rust remover additive in them to take the rust off. If you use to much of it in the tank you end up with a coating on the part that looks grey instead of how clean cast iron does I agree with John Kunkel on that part that looks like it has been cooked and iron bead blasted
Re: cleaining the inside of a 8.75 housing [Re: Cab_Burge] #1343470
12/02/12 11:27 PM
12/02/12 11:27 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
x 99 on finding another housing. IF it is that bad there ... it has to be a horror-show on and in the axle bearing ends.
Re: cleaining the inside of a 8.75 housing [Re: ] #1343471
12/03/12 01:35 AM
12/03/12 01:35 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
I just had my Dana 60 housing cleaned up. I had it sit in a solvent tank over a weekend, then I had it Acid dipped. The grease, and rust is gone....looks great.
Now it's going to get powder coated.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
