Remote oil filter line size #1343113
11/29/12 09:32 PM
11/29/12 09:32 PM
ont,canada
mopartuner Offline OP
ont,canada
I am going to mount my oil filter on the inner fender and was thinking of using 10 an line and fittings.Is this big enough?
410 pump gas solis flat tappet cam 10.95 so far
Re: Remote oil filter line size [Re: mopartuner] #1343114
11/29/12 09:36 PM
11/29/12 09:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats PLENTY big enough... I ran -8.... the stock
pick up isnt even that big
Re: Remote oil filter line size [Re: MR_P_BODY] #1343115
11/29/12 09:56 PM
11/29/12 09:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I ran -10 on my Duster, but as Mr. P points out, -8 is 1/2" and that's as big - or bigger - than many pickup tubes.
One side-effect of a remote filter is it takes a bit longer to spool up oil pressure, so don't be surprised by that.
Re: Remote oil filter line size [Re: topside] #1343116
11/29/12 10:45 PM
11/29/12 10:45 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I use -10's also
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Remote oil filter line size [Re: mopartuner] #1343117
11/29/12 11:27 PM
11/29/12 11:27 PM
Keep the I.D. of the hose the same I.D. as the orifice your feeding it out or bigger BTW, what type of remote filter mount and which filter are you going to use?
Re: Remote oil filter line size [Re: Cab_Burge] #1343118
11/29/12 11:49 PM
11/29/12 11:49 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Mine is #12 from pan to pump and #10 to and from the filter. So much nicer to change oil filters now (not so messy). Oil pressure is immediate upon cranking, 75 lbs at all times.
Brian Dunnigan
Re: Remote oil filter line size [Re: '72CudaRacer] #1343119
11/30/12 01:16 AM
11/30/12 01:16 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
-10 here
Re: Remote oil filter line size [Re: rebel] #1343120
11/30/12 01:46 AM
11/30/12 01:46 AM
PA
moparacer Offline
moparacer  Offline
PA
When I remote a filter I always use -10.
Thats a different deal then you have with the milodon setup where the line is feeding the oil pump. A remote is moving pressurized oil through the filter. -10 is plenty big enough IMO.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Remote oil filter line size [Re: Cab_Burge] #1343121
11/30/12 06:02 AM
11/30/12 06:02 AM
ont,canada
ont,canada
Keep in mind that this is a small block and all I am trying to do is get rid of the factory 90 deg adaptor so I don't get my new headers oiled up.I usually use a stock Napa Gold filter.I am going to use the Moroso mount,it has a spot for a guage too.
Re: Remote oil filter line size [Re: mopartuner] #1343122
11/30/12 09:39 AM
11/30/12 09:39 AM
an8sec70cuda Offline
I have -12 from the sump to the pump, then -10 lines from the pump to the filter.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Remote oil filter line size [Re: mopartuner] #1343123
11/30/12 10:25 AM
11/30/12 10:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
-8 or -10 will work fine.... I went with the -8 on
my 416 and on the dyno it proved to be fine... I
moved the filter towards the front on the frame rail
Re: Remote oil filter line size [Re: MR_P_BODY] #1343124
11/30/12 05:11 PM
11/30/12 05:11 PM
ont,canada
ont,canada
I am a little tight for space in my early A body so I think I will go with the #8........thanks
