Remote oil filter line size
#1343113
11/29/12 09:32 PM
11/29/12 09:32 PM
Posts: 614 ont,canada
mopartuner
ont,canada
I am going to mount my oil filter on the inner fender and was thinking of using 10 an line and fittings.Is this big enough?
410 pump gas solis flat tappet cam 10.95 so far
Re: Remote oil filter line size
[Re: mopartuner]
#1343114
11/29/12 09:36 PM
11/29/12 09:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats PLENTY big enough... I ran -8.... the stock pick up isnt even that big
[Re: mopartuner]
#1343117
11/29/12 11:27 PM
11/29/12 11:27 PM
Posts: 43,198 Bend,OR USA
Cab_Burge
Keep the I.D. of the hose the same I.D. as the orifice your feeding it out or bigger BTW, what type of remote filter mount and which filter are you going to use?
[Re: rebel]
#1343120
11/30/12 01:46 AM
11/30/12 01:46 AM
Posts: 2,507 PA
moparacer
PA
When I remote a filter I always use -10.
Thats a different deal then you have with the milodon setup where the line is feeding the oil pump. A remote is moving pressurized oil through the filter. -10 is plenty big enough IMO.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: mopartuner]
#1343122
11/30/12 09:39 AM
11/30/12 09:39 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
I have -12 from the sump to the pump, then -10 lines from the pump to the filter.
[Re: mopartuner]
#1343123
11/30/12 10:25 AM
11/30/12 10:25 AM
MR_P_BODY
Keep in mind that this is a small block and all I am trying to do is get rid of the factory 90 deg adaptor so I don't get my new headers oiled up.I usually use a stock Napa Gold filter.I am going to use the Moroso mount,it has a spot for a guage too.
-8 or -10 will work fine.... I went with the -8 on my 416 and on the dyno it proved to be fine... I moved the filter towards the front on the frame rail
