Which wide band and why? #1342223
11/27/12 02:27 PM
11/27/12 02:27 PM
Sterling Hts, MI
2
2FASTCORONET Offline OP
Sterling Hts, MI
I'm tired of being out of tune and guessing at the changes. Which wide band, I'm thinking dual sensors. Ive seen FAST and Innovate.
Thanks Dennis
I just found a Nov 13 post, mostly problems, no recomendations.
Re: Which wide band and why? [Re: 2FASTCORONET] #1342224
11/27/12 03:08 PM
11/27/12 03:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Innovate here but w/one sensor...............works great and will verify tuning changes both good and bad.
Re: Which wide band and why? [Re: Thumperdart] #1342225
11/27/12 03:35 PM
11/27/12 03:35 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
The NGK one is the best of the sub $500 units for heater control and sensor life, but it is fairly limited in other features. Can't display in lambda, no datalogging, single sensor only. It does have an output to connect it to other equipment though.
Re: Which wide band and why? [Re: 2FASTCORONET] #1342226
11/27/12 03:45 PM
11/27/12 03:45 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I run a FAST dual sensor and love it. I use it on the dyno and in cars and have never had an issue other than the optional rpm module includes an inductive pickup that is not the best.
If I use the tach feed off an MSD it works fine.
Keith
Re: Which wide band and why? [Re: Dunnuck Racing] #1342227
11/27/12 05:16 PM
11/27/12 05:16 PM
Sterling Hts, MI
2
Sterling Hts, MI
Thanks to everyone for the replies
Re: Which wide band and why? [Re: 2FASTCORONET] #1342228
11/27/12 06:36 PM
11/27/12 06:36 PM
Washington
skrews Offline
skrews  Offline
Washington
AEM. Easy to read digital display, low cost, and hasn't died yet (5 years). One of the best thing I've ever bought for the car.
Re: Which wide band and why? [Re: skrews] #1342229
11/27/12 08:29 PM
11/27/12 08:29 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I love my Innovate LM-2. I bought it off ebay for alittle under $300 new and got an input cable to input RPM for another $20. It data logs to an SD card and comes with software to analyze it on the computer. It pays to have a datalogger so you are not limited to watching the gauge down the track. Most gauges don't update fast enough to find smaller problems but if its recorded you can track things down much easier. It can also read OBD2 live data with a change of a cable and read DTC's(I think).
Re: Which wide band and why? [Re: SLOW67] #1342230
11/27/12 10:17 PM
11/27/12 10:17 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I like my innovate MTX-L...handy little gauge for tuning that works quite well, records (only time based, not rpm) to a computer to watch the run over, and the price was right at only 165 shipped brand new
Re: Which wide band and why? [Re: mshred] #1342231
11/27/12 10:36 PM
11/27/12 10:36 PM
right between milan dragway & ...
Flite_727 Offline
Flite_727  Offline
not to hijack the thread, but anybody have any feedback on the 14point7 wideband?? seems like it has alot of features for under $300 (AFR, lambda, datalogging, etc)
they also have a self assemble version even cheaper.
http://www.14point7.com/
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: Which wide band and why? [Re: SLOW67] #1342232
11/27/12 10:38 PM
11/27/12 10:38 PM
Andrews,In. U.S.of A.
67_Satellite Offline
"I love my Innovate LM-2. I bought it off ebay for alittle under $300 new and got an input cable to input RPM for another $20. It data logs to an SD card and comes with software to analyze it on the computer. It pays to have a datalogger so you are not limited to watching the gauge down the track. Most gauges don't update fast enough to find smaller problems but if its recorded you can track things down much easier. It can also read OBD2 live data with a change of a cable and read DTC's(I think)". This has been my experience also. Playback on the computer in slo-mo helped me confirm a problem I suspected, and saved a bunch of trial & error tuning. Buy one.
