Turbo Small Block E-Body Help #1342192
11/27/12 01:50 PM
11/27/12 01:50 PM
N. Of Detroit, Mi
733404spdCuda Offline OP
N. Of Detroit, Mi
With all the chat around here about turbo’s I’m thinking about building a nice 408 small block with a turbo for street / strip use.
My dilemma is that I don’t want to cut the fender wells up.
If anyone can post pictures of E-body’s with a nice clean turbo set-up and detail I would appreciate it.
Re: Turbo Small Block E-Body Help [Re: 733404spdCuda] #1342193
11/27/12 01:53 PM
11/27/12 01:53 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Search for "instigator"
He was somewhere on the east coast and had a gold turbo SB e-body.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Turbo Small Block E-Body Help [Re: AlexP] #1342194
11/27/12 02:14 PM
11/27/12 02:14 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I don't have any completed pics of mine yet. Still gathering parts for the build. But I am going to be trying to do the same with this in my E-Body. (Twins with a 2ND Gen HEMI though).
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Turbo Small Block E-Body Help [Re: 733404spdCuda] #1342195
11/27/12 03:32 PM
11/27/12 03:32 PM
DRAG-ULA Offline
DRAG-ULA  Offline
Sorry, no pics of an E body bay, but if you get a game plan down before you start doing anything and plan ahead, it'll turn out nice. I only had to do very minimal cutting on my Coronet to make everything fit by thinking it through first.
1970 Imperial, Low & slow daily driver
1973 Chrysler T&C
1948 Dodge B1 pickup - perpetual project
Re: Turbo Small Block E-Body Help [Re: DRAG-ULA] #1342196
11/27/12 07:02 PM
11/27/12 07:02 PM
N. Of Detroit, Mi
N. Of Detroit, Mi
John - I picked up a 8 3/4 3.91 pig from you a year ago at Robs shop, you showed me your car then and I've been thinking about a turbo ever since. Are you still at Rob's?
Re: Turbo Small Block E-Body Help [Re: 733404spdCuda] #1342197
11/27/12 07:49 PM
11/27/12 07:49 PM
DRAG-ULA Offline
DRAG-ULA  Offline
No, not at robs anymore. Turbos are the way to go for a street car, I love the way mine turned out. It's quiet, docile on the street and it gets down pretty good.
1973 Chrysler T&C
Re: Turbo Small Block E-Body Help [Re: DRAG-ULA] #1342198
11/27/12 08:03 PM
11/27/12 08:03 PM
Post falls, Idaho
rgreule Offline
rgreule  Offline
Post falls, Idaho
not a e body.. but here is the turbo setup i built for my duster.. it was very key to me to not cut a single bit of the engine bay...
made with 304 schedule 10 stainless
Re: Turbo Small Block E-Body Help [Re: rgreule] #1342199
11/27/12 11:54 PM
11/27/12 11:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Depending on how fast you want to go you don't really need headers. Small block truck manifolds get the job done on Dizusters 10 second B-Body. He cut the inner fender only to hide the air filter. I drove this thing on the street on Thanksgiving. First gear is useless even with a 2.76 gear.
Doug
Re: Turbo Small Block E-Body Help [Re: rgreule] #1342200
11/28/12 10:35 AM
11/28/12 10:35 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Big primiaries for a turbo app are not needed unless you are turning some rpms or have huge displacement... I see he is using a W5 so he may turn some rpms..
I use a pair of stainless shorties flipped.
Re: Turbo Small Block E-Body Help [Re: TheOtherDodge] #1342201
11/28/12 05:38 PM
11/28/12 05:38 PM
IL
furious70 Offline
furious70  Offline
IL
I'll add unless you already have the 408 built, you don't need it. 340-360" is more than enough with pressure and the smaller engine makes the turbo(s) cheaper and more often than not, better fitting into the compressor map: i.e. a 340" engine running 15psi has more good fitting turbos available to it than a 408" @ 6-8psi.
70 Sport Fury
68 Charger
69 Coronet
72 RR
