Piston rings..what to use ? makes my head spin..napier #1341640
11/26/12 01:56 PM
11/26/12 01:56 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Happy Birthday VernMotor  Offline OP
Mt.Vernon ,Ohio
ok I going to use SRP pistons 1/16-1/16-3/16 with a 4.350 bore. so many Diff kinds... what about napier second ring ? bracket motor.
Re: Piston rings..what to use ? makes my head spin..napier [Re: VernMotor] #1341641
11/26/12 02:23 PM
11/26/12 02:23 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Well after reading ..about Napier second rings.. sounds like a geat deal.. anyone find a part number for a set that has them in it ?
Re: Piston rings..what to use ? makes my head spin..napier [Re: VernMotor] #1341642
11/26/12 02:51 PM
11/26/12 02:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Pettis hooked me up w/a standard moly top, napier second and medium oil ring pack plus he back-cut the top n second rings............so far so good.
Re: Piston rings..what to use ? makes my head spin..napier [Re: VernMotor] #1341643
11/26/12 03:01 PM
11/26/12 03:01 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Summit racing has them in Mahle brand.I use these rings in my smallblock.
Mahle Original Precision-Ground Performance Piston Rings 3150075-035
Re: Piston rings..what to use ? makes my head spin..napier [Re: WheelsUp73] #1341644
11/26/12 06:10 PM
11/26/12 06:10 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Thanks I found them at summit for a big block
Re: Piston rings..what to use ? makes my head spin..napier [Re: VernMotor] #1341645
11/26/12 07:11 PM
11/26/12 07:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Might be worth it to see if they can back cut em then use their spacer material and you`re good to go.
Re: Piston rings..what to use ? makes my head spin..napier [Re: Thumperdart] #1341646
11/26/12 07:23 PM
11/26/12 07:23 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Why would you do that ?
Re: Piston rings..what to use ? makes my head spin..napier [Re: VernMotor] #1341647
11/26/12 07:56 PM
11/26/12 07:56 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
You wouldnt and there would be no benefit.
Don't make it harder than it is.
Re: Piston rings..what to use ? makes my head spin..napier [Re: WheelsUp73] #1341648
11/26/12 08:16 PM
11/26/12 08:16 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Jason Pettis recommended it and so far so good on oil controll and this motor is WAY easier to turn over than any others prior. Jason knows his stuff and I`ll leave it there............
Re: Piston rings..what to use ? makes my head spin..napier [Re: VernMotor] #1341649
11/26/12 08:42 PM
11/26/12 08:42 PM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
hi, because it's worth more horsepower!! less friction on bores. motor rolls easier. thats why stockers and super stockers go so fast.
Re: Piston rings..what to use ? makes my head spin..napier [Re: perfmachst] #1341650
11/26/12 08:56 PM
11/26/12 08:56 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Well if I was running a stocker that would be cool. But I am not ..this is a old trick been around for many years. takes tension out of the rings and they do not last as long. Not something I want to take chance on in a bracket motor. I have seen many of them break also.
Re: Piston rings..what to use ? makes my head spin..napier [Re: VernMotor] #1341651
11/26/12 09:02 PM
11/26/12 09:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine`s a street car that I race..........My plugs look great and it hauls azz plus you`d be surprised how many production cars practice this "un-needed" trick.
Re: Piston rings..what to use ? makes my head spin..napier [Re: VernMotor] #1341652
12/03/12 01:21 AM
12/03/12 01:21 AM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
hi, actually, they last longer, detroit went to low tension, metric rings few years ago , found more power, more fuel milage, less wear in bores. they make low tension rings for most engines. I've ran over 4 years on metric , low tension rings. over 400 runs. and they didn't break!!!!
