Re: Piston rings..what to use ? makes my head spin..napier
[Re: VernMotor]
#1341643
11/26/12 03:01 PM
11/26/12 03:01 PM
Posts: 369 California, USA!!!
WheelsUp73
California, USA!!!
Well after reading ..about Napier second rings.. sounds like a geat deal.. anyone find a part number for a set that has them in it ?
Summit racing has them in Mahle brand.I use these rings in my smallblock. Mahle Original Precision-Ground Performance Piston Rings 3150075-035
[Re: Thumperdart]
#1341646
11/26/12 07:23 PM
11/26/12 07:23 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Thanks I found them at summit for a big block
Might be worth it to see if they can back cut em then use their spacer material and you`re good to go.
Why would you do that ?
[Re: VernMotor]
#1341647
11/26/12 07:56 PM
11/26/12 07:56 PM
WheelsUp73
California, USA!!!
You wouldnt and there would be no benefit. Don't make it harder than it is.
[Re: VernMotor]
#1341652
12/03/12 01:21 AM
12/03/12 01:21 AM
Posts: 170 renton , washington
perfmachst
renton , washington
hi, actually, they last longer, detroit went to low tension, metric rings few years ago , found more power, more fuel milage, less wear in bores. they make low tension rings for most engines. I've ran over 4 years on metric , low tension rings. over 400 runs. and they didn't break!!!!
