70 SuperBee engine wiring harness #1341260
11/25/12 07:44 PM
11/25/12 07:44 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
Here's the question..Would you repair or replace engine wiring harness on a survivor car? I'm having the typicial alt.and temp. wiring ends/wires cracking.Also what have you fould is the best source for each??? I'm not sure which way to go......
Re: 70 SuperBee engine wiring harness [Re: Hemiruss] #1341261
11/25/12 08:33 PM
11/25/12 08:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I'd replace it but save the original... Bad wiring causes bigger issues than survivor status questions....
Re: 70 SuperBee engine wiring harness [Re: 1_WILD_RT] #1341262
11/25/12 08:57 PM
11/25/12 08:57 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Re: 70 SuperBee engine wiring harness [Re: 1_WILD_RT] #1341263
11/25/12 09:26 PM
11/25/12 09:26 PM
FJ5 Acres, Colorado
Stage-III Offline
Stage-III  Offline
FJ5 Acres, Colorado
Agreed, get the bad wiring out and test it if you like. You can always put it back in if you find and fix a bad spot.
I re-wired my former '70 Super Bee with Year One harnesses. The engine and forward light harnesses were a good fit and cured some annoying problems. I didn't inspect them closely to see how they compared to the old harnesses as originality was not my primary concern on that car.
Re: 70 SuperBee engine wiring harness [Re: Stage-III] #1341264
11/26/12 12:25 AM
11/26/12 12:25 AM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
So it looks like Year One might be the answer....What did it cost??
Re: 70 SuperBee engine wiring harness [Re: Hemiruss] #1341265
11/26/12 03:27 AM
11/26/12 03:27 AM
FJ5 Acres, Colorado
Stage-III Offline
Stage-III  Offline
FJ5 Acres, Colorado
Re: 70 SuperBee engine wiring harness [Re: moparpollack] #1341266
11/26/12 01:32 PM
11/26/12 01:32 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
x 2. Get the M&H Harness from Year One; it isn't perfect but it's close.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
