how much can it rev? cast crank #1341148
11/25/12 05:14 PM
11/25/12 05:14 PM
ontario canada kingston
aspenrt360 Offline OP
Hey guy's this is a bit out of my area so i figured i would chime in here. i have a good friend who has built himself up a 360 with a stock style cast crank it has been cut .010 fully balanced and he is using eagle h beam rods and kb 107's what can this set up reasonably take rpm wise? thanks
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: how much can it rev? cast crank [Re: aspenrt360] #1341149
11/25/12 05:55 PM
11/25/12 05:55 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
I have a friend that runs his up to 7 grand on occasion, typically 6500 upshifts, same combo with 509 mp cam
Re: how much can it rev? cast crank [Re: gtsdude] #1341150
11/25/12 06:08 PM
11/25/12 06:08 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I ran mine to 6800 every pass for years, but my valve train could handle it, stock 360 crank is pretty stout, but who made the stock style crank....? Eagle?
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: how much can it rev? cast crank [Re: Adobedude] #1341151
11/25/12 06:09 PM
11/25/12 06:09 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
I used to turn mine 6500 to 6800 all the time.....
Re: how much can it rev? cast crank [Re: domingo] #1341152
11/25/12 07:38 PM
11/25/12 07:38 PM
it is an actual mopar crank with a bit of prep work nothing major. thanks for the replies i can't see it getting over 6400 just want to get a feel for what guy's have been able to do with them.
Re: how much can it rev? cast crank [Re: aspenrt360] #1341153
11/25/12 07:44 PM
11/25/12 07:44 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
It wont even break a sweat.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: how much can it rev? cast crank [Re: aspenrt360] #1341154
11/25/12 08:05 PM
11/25/12 08:05 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I shift at 6,200 rpm. Rev limiter is set at 6,600 and I've bounced off it a couple of times. Chrysler claimed in their engine book that they are good for 7,000 rpm. I am not sure I would try this on a circle track or road race engine due to all the thrust reverseals. My crank is an original '79 CFD casting that is internally balanced and polished, but never turned, still standard size. It's also been in two different blocks and must have at least 300,000 miles on it by now. Chrysler had two different sources for 360 cranks. Both are cast, and most were cast in a Chrysler foundry. Some however were cast by GM for Chrysler and are identified by the letters CFD. Or at least that's what I've been told.
Re: how much can it rev? cast crank [Re: aspenrt360] #1341155
11/25/12 08:17 PM
11/25/12 08:17 PM
AndyF Offline
AndyF  Offline
Super Stock guys run the cast cranks because they are lighter. Those motors spin pretty hard. 7500 or so?
Re: how much can it rev? cast crank [Re: 5spdcuda] #1341156
11/25/12 10:31 PM
11/25/12 10:31 PM
ill
dennismopar73 Offline
ill
Hi there Hugh!!!
Alot does depend on how the motor was built mainly valvesprings/cam pick and of course rod bolts .
I have been with a guy who races and drives alot of 360 he can go in the 7 grand rang plus.
I have seen shifts upwards of 7200 and he gets quite a few years out of a motor .
Now i have ran 360 in my old street car and shifted @ 5800 mark drove that car for well over 13 years I built the motor in 1992, the motor was not even balanced!! That exact motor is still running to this day,
Anytime you race one hard the life espectancy come into play,,but with care upkeep ,
that motor can run a very very long time !!
But the biggest deal is to build it right
Re: how much can it rev? cast crank [Re: dennismopar73] #1341157
11/25/12 11:30 PM
11/25/12 11:30 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Used to shift at 7,500 and go through traps over 8,000 with a cast steel truck crank.
Re: how much can it rev? cast crank [Re: Leon441] #1341158
11/26/12 12:00 AM
11/26/12 12:00 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
8000 rpm with 550hp is alot different than 8000rpm with 650hp. And those shot peened truck cranks were great cranks.
Mopar to the bone!!!
Re: how much can it rev? cast crank [Re: 72Swinger] #1341159
11/26/12 01:46 AM
11/26/12 01:46 AM
Toronto
mshred Offline
mshred  Offline
Toronto
shot peened truck cranks? Is this how they came? what were they found in?
Re: how much can it rev? cast crank [Re: mshred] #1341160
11/26/12 01:50 AM
11/26/12 01:50 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
shot peen truck cranks can be found in trucks...lol
Tony
70 AARCuda Vitamin C
Re: how much can it rev? cast crank [Re: 70AARcuda] #1341161
11/26/12 01:55 AM
11/26/12 01:55 AM
Toronto
mshred Offline
mshred  Offline
Toronto
lol duh....but I have a 91 360 out of a truck....is shot peening something you can see??? cuz it didn't seem like a special crank to me
Re: how much can it rev? cast crank [Re: mshred] #1341162
11/26/12 04:45 AM
11/26/12 04:45 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I believe they were 74 only that got peened.
Re: how much can it rev? cast crank [Re: 72Swinger] #1341163
11/26/12 12:57 PM
11/26/12 12:57 PM
thanks for all the info guy's, it will never see 7000! shift point should be about 6200 so i was just looking to see what kind of wiggle room he would have.
Re: how much can it rev? cast crank [Re: aspenrt360] #1341164
12/03/12 02:58 AM
12/03/12 02:58 AM
Red Deer, Alberta
bill_greenwood Offline
Red Deer, Alberta
Internally balanced cast unit in mine sees 71-7200 every pass.
Re: how much can it rev? cast crank [Re: bill_greenwood] #1341165
12/03/12 02:18 PM
12/03/12 02:18 PM
dogdays Offline
dogdays  Offline
As the main journal size is larger than a 440 main, the crank should be pretty stiff. That's good, I believe most crank failures that start out as crank failures come from fatigue due to flexing.
R.
Re: how much can it rev? cast crank [Re: dogdays] #1341166
12/03/12 02:34 PM
12/03/12 02:34 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
x99 on actually higher potential R's due to the crank THUS the rotating-assembly being able to be made lighter. The big downer on a cast crank is a heavy weight car ... then add that to the shock of a stick shift combo.
