Torque Converter Screw
#1341079
11/25/12 01:50 PM
11/25/12 01:50 PM
Posts: 1,534 Florida
CHRGR69
69 Charger 440. Have a slight vibration at idle, and while checking the converter screws, not only was one of them loose, it was a Heli-Coil gone bad. Any suggestions on a repair?
Grandma always said I had "hands of gold"!
Re: Torque Converter Screw
[Re: MoparforLife]
#1341083
11/27/12 04:48 PM
11/27/12 04:48 PM
CHRGR69
I Have tapped to the next oversize with no problems. Not enough weight difference to cause a balance problem either. The 5/16 converter bolt head is 9/16 as is a 3/8 bolt. Grind some of the head face to clear the block webbing.
Yep much easier. So tapping UP to 3/8"? Any thoughts where I can scavenge this bolt off the car from?
[Re: CHRGR69]
#1341084
11/27/12 04:52 PM
11/27/12 04:52 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Fine thread and be careful you don't punch a hole in the convertor .
Have you tried to install a new helicoil of the current size ?
[Re: JohnRR]
#1341085
11/27/12 05:12 PM
11/27/12 05:12 PM
CHRGR69
No have not tried another Heli-Coil. Don't want the same issue though
[Re: CHRGR69]
#1341086
11/27/12 06:43 PM
11/27/12 06:43 PM
JohnRR
if the helicoil was installed properly the first time there would be no issue to begin with ... i suppose ???
