Re: 03' Dodge Stratus Build video
[Re: Charger453]
#1340950
11/25/12 10:15 AM
11/25/12 10:15 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Congratulations, very nice video and your car turned out beautiful. I only wish I had that kind of patience and talent to build a tube chassis car from start to finish. Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Forest]
#1340954
11/25/12 02:19 PM
11/25/12 02:19 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Wow nice build, now I just have to learn to tig weld...
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: cesar perez]
#1340958
11/25/12 08:45 PM
11/25/12 08:45 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
how much would this cost to build
A few gallons of blood, sweat, and tears... And a good chunk of cash.
Amazing work, you should be extremely proud of your creation.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: DusterDave]
#1340962
11/25/12 11:44 PM
11/25/12 11:44 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Very nice build and great job on the video. Thanks for sharing your build with us. What wheelbase did you end up with?
[Re: Forest]
#1340963
11/25/12 11:53 PM
11/25/12 11:53 PM
Posts: 914 tn
robnbird
tn
[Re: cesar perez]
#1340964
11/26/12 12:00 AM
11/26/12 12:00 AM
Posts: 916 SE Washington
Forest
SE Washington
Well to be completely honest I have 35k in the car right now. Everything is new other than the motor and trans I recycled from my Dart. That is only parts no labor, but putting some value to the motor and trans in that 35k.
Bandit, Yes I have been doing side work since 03' that is how I have been able to afford to fund this car...and an understanding wife too. The wheel base was stretched 2" from stock, I didn't modify the front fenders though. All the factory sheetmetal was reused other than a glass hood. What I found out after I was commited to this body is with there being a 5 Star fiberglass body for Pro Stock nobody ever made fiberglass parts like doors, fenders or a trunk lid, so I was stuck lightening that stuff as much as possible. As you know there are parts for the older Avengers.
Thanks again everyone for all the kind words!
[Re: pittsburghracer]
#1340965
11/26/12 12:02 AM
11/26/12 12:02 AM
Forest
SE Washington
To clarify my last post wheelbase ended up at 105"
[Re: Thumperdart]
#1340967
11/26/12 12:18 AM
11/26/12 12:18 AM
Forest
SE Washington
WAY cool and a beautifull ride. I would assume you would have plans for an engine swap down the road since it`s certed for the 6`s..............
Yea for sure, I want to build a 572 for it. Plan to run the div. 6 races this year and see what happens from there.
[Re: Forest]
#1340969
11/26/12 12:33 AM
11/26/12 12:33 AM
Did you do all the carbon fiber work like the tubs yourself?
Simply awesome!
I can't fathom putting together a chassis like that.
The fact that it ran straight as a string down the dragstrip was pretty amazing too!
#1340971
11/26/12 01:28 AM
11/26/12 01:28 AM
Forest
SE Washington
Simply awesome!
Yes I did all the carbon fiber work too. What a scary day that was cutting the tubs off the template i had been working on! I nicknamed my wife cranky because she runs the crank on the bead roller as I feed in the material; we have become a pretty good team when it comes to that!
Yea I was pretty stoked just to get past the first 6 licensing passes without any issues, but to turnaround and put 4 more 1/8 mile passes and 6 1/4 mile passes on it and not do anything besides adjust tire pressures was quite nice!
[Re: Forest]
#1340972
11/26/12 09:44 PM
11/26/12 09:44 PM
Posts: 422 montana
BANDIT
montana
What did it end up weighing with the smallblock in it? Where did you add the 2 inches in wheelbase? Again, awesome work, Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: BANDIT]
#1340973
11/26/12 10:04 PM
11/26/12 10:04 PM
Forest
SE Washington
The front tire is just moved forward 2" from the center of the opening in the fender...
