Re: 03' Dodge Stratus Build video
[Re: Charger453]
#1340950
11/25/12 10:15 AM
11/25/12 10:15 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Congratulations, very nice video and your car turned out beautiful. I only wish I had that kind of patience and talent to build a tube chassis car from start to finish. Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Forest]
#1340954
11/25/12 02:19 PM
11/25/12 02:19 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Wow nice build, now I just have to learn to tig weld...
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: cesar perez]
#1340958
11/25/12 08:45 PM
11/25/12 08:45 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
how much would this cost to build
A few gallons of blood, sweat, and tears... And a good chunk of cash.
Amazing work, you should be extremely proud of your creation.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: DusterDave]
#1340962
11/25/12 11:44 PM
11/25/12 11:44 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Very nice build and great job on the video. Thanks for sharing your build with us. What wheelbase did you end up with?
[Re: Forest]
#1340963
11/25/12 11:53 PM
11/25/12 11:53 PM
Posts: 914 tn
robnbird
tn
[Re: cesar perez]
#1340964
11/26/12 12:00 AM
11/26/12 12:00 AM
Posts: 916 SE Washington
Forest
SE Washington
Well to be completely honest I have 35k in the car right now. Everything is new other than the motor and trans I recycled from my Dart. That is only parts no labor, but putting some value to the motor and trans in that 35k.
Bandit, Yes I have been doing side work since 03' that is how I have been able to afford to fund this car...and an understanding wife too. The wheel base was stretched 2" from stock, I didn't modify the front fenders though. All the factory sheetmetal was reused other than a glass hood. What I found out after I was commited to this body is with there being a 5 Star fiberglass body for Pro Stock nobody ever made fiberglass parts like doors, fenders or a trunk lid, so I was stuck lightening that stuff as much as possible. As you know there are parts for the older Avengers.
Thanks again everyone for all the kind words!
[Re: pittsburghracer]
#1340965
11/26/12 12:02 AM
11/26/12 12:02 AM
Forest
SE Washington
To clarify my last post wheelbase ended up at 105"
