trunion drive shaft availability #1340176
11/23/12 06:54 PM
11/23/12 06:54 PM
MICHIGAN
BB65Barracuda Offline OP
MICHIGAN
The car im building is a 64 426/ A833 Coronet.
It was in a 65 B Body but trunnion plate is larger than the trunnion that was on my 727 / small block set up the car came with. So my Drive shaft will not work. How hard is it to find the larger trunnion drive shaft or is there a bolt on adapter to use a smaller unit.
Or for that matter a slip yoke?
Im hoping a trans tail shaft change is not in the future.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: trunion drive shaft availability [Re: BB65Barracuda] #1340177
11/23/12 07:07 PM
11/23/12 07:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Most any driveline shop can fix you up with B&T substitute that has the slip joint in the driveshaft.
Re: trunion drive shaft availability [Re: John_Kunkel] #1340178
11/23/12 07:15 PM
11/23/12 07:15 PM
MICHIGAN
MICHIGAN
That is pretty neat piece! Was it incredibly costly?Is there any problem with the larger trunnion plate? I was asked if it was from a truck but it was not. It was a BB though.
Re: trunion drive shaft availability [Re: John_Kunkel] #1340179
11/24/12 01:19 AM
11/24/12 01:19 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Who did that shaft/ where can I get the Ujoint adapter? Tim
Re: trunion drive shaft availability [Re: BB65Barracuda] #1340180
11/24/12 11:50 AM
11/24/12 11:50 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
When I converted my '65 to a 4 speed, I used a '70 trans. Simple matter of modifying the crossmember to use later model trans mount and changing the speedo cable. The stock (slip joint) 727 shaft fit perfectly. When you figure the cost of an early "B" 833 crossmember and mount and the cost of a shaft, a later trans may be more economical, too.
This is the land of the free because of the brave
Re: trunion drive shaft availability [Re: rbstroker] #1340181
11/24/12 12:03 PM
11/24/12 12:03 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
But.... with the later transmission, did you ever have to R & R the clutch after it was assembled? I put a later 4 speed in my 65 Polara years ago, which worked fine until I had to change the clutch. Seems that slip yoke tail is enough longer so I had to either lift the engine forward ~ 4" or remove the rear torsion bar support to get the input shaft out of the bellhousing. So the next time and next 65 Polara I used the correct trunnion output trans and all is so much easier.
Mike
Re: trunion drive shaft availability [Re: 1E2C] #1340182
11/24/12 01:01 PM
11/24/12 01:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Two differten bodys.My 65 when you drop the trans support there is nothing in the way.Trans drops right out.Ive thought about changing it to slip yoke but my 45 year old B&T is still as good as new.Ive broken rear joints but never a front B&T.Rocky
Chrysler Firepower
Re: trunion drive shaft availability [Re: therocks] #1340183
11/24/12 01:14 PM
11/24/12 01:14 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Never realized there was that much difference between the B and C bodies. Thanks for the info Rocky. And I was hard on a clutch back then, I think I did 3 of them with that setup. I actually got pretty good at getting that long tranny out of there even though it was a pain in the butt.
Mike
Re: trunion drive shaft availability [Re: BB65Barracuda] #1340184
11/24/12 03:19 PM
11/24/12 03:19 PM
You have a PM
Re: trunion drive shaft availability [Re: 1E2C] #1340185
11/24/12 08:42 PM
11/24/12 08:42 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Mike
I had the trans in and out a few times during mockup. No issues whatsoever.
