trunion drive shaft availability
#1340176
11/23/12 06:54 PM
11/23/12 06:54 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
The car im building is a 64 426/ A833 Coronet. It was in a 65 B Body but trunnion plate is larger than the trunnion that was on my 727 / small block set up the car came with. So my Drive shaft will not work. How hard is it to find the larger trunnion drive shaft or is there a bolt on adapter to use a smaller unit. Or for that matter a slip yoke? Im hoping a trans tail shaft change is not in the future.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: trunion drive shaft availability
[Re: John_Kunkel]
#1340178
11/23/12 07:15 PM
11/23/12 07:15 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
That is pretty neat piece! Was it incredibly costly?Is there any problem with the larger trunnion plate? I was asked if it was from a truck but it was not. It was a BB though.
[Re: BB65Barracuda]
#1340180
11/24/12 11:50 AM
11/24/12 11:50 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
When I converted my '65 to a 4 speed, I used a '70 trans. Simple matter of modifying the crossmember to use later model trans mount and changing the speedo cable. The stock (slip joint) 727 shaft fit perfectly. When you figure the cost of an early "B" 833 crossmember and mount and the cost of a shaft, a later trans may be more economical, too.
This is the land of the free
because of the brave
[Re: 1E2C]
#1340182
11/24/12 01:01 PM
11/24/12 01:01 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Two differten bodys.My 65 when you drop the trans support there is nothing in the way.Trans drops right out.Ive thought about changing it to slip yoke but my 45 year old B&T is still as good as new.Ive broken rear joints but never a front B&T.Rocky
Chrysler Firepower
