Page 3 of 4 1 2 3 4
Re: PROCHARGER VS. TURBO [Re: Crizila] #1340118
11/26/12 12:13 AM
11/26/12 12:13 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
IMO, the benefits of a turbo on a "street car" out weigh a supercharger.
Much more quiet since the turbo eats up some of the exh sound.
You can run a very, very numerically low gear.
You can run a very tight converter.
Re: PROCHARGER VS. TURBO [Re: bigtimeauto] #1340119
11/26/12 08:58 PM
11/26/12 08:58 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
pretty simple if you ask me:
That's one more 90 degree bend then my turbo has on my cold side....
And I have single exhaust, so that's only half the work there too! LOL...
I know you LOVE staging at idle, but I bet you'd love you car even more if it were faster with a turbo and all you had to do is put it on a two step during staging...
But I understand... going slow is a good trade off for easy staging.
Re: PROCHARGER VS. TURBO [Re: TheOtherDodge] #1340120
11/26/12 09:21 PM
11/26/12 09:21 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Also from what I've seen at the track Superchargers are more consistant.. Seems a lot of the turbo guys have an issue here and there, one run will be fast as nutz and then for no reason it will drop a some et... Just going from what I've seen.
Re: PROCHARGER VS. TURBO [Re: bigtimeauto] #1340121
11/26/12 10:02 PM
11/26/12 10:02 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
the heads were the first set of mopar heads i ever bought. My goal was to make 875 NA and i was told they would work, After i decided to procharge it all i did was change the cam, pistons make a 4150 intake adapter and that was it.
Yes a engine needs to make real good power by itself or the boost won't be as big as a gain as it can be. Don't forget i don't turn this blower hard either it only see's 22lbs in the 1/8 and 24 in the 1/4.
Boost is only a measurement of restriction.
The restriction are those heads
Re: PROCHARGER VS. TURBO [Re: Defbob] #1340122
11/26/12 10:12 PM
11/26/12 10:12 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
superchargers build power in a very consistent manner and can/will make more torque from launch, allowing the car to '60 much quicker than a turbocharged car. That is why when you see outlaw cars that run identical e/t's, the supercharged car will tend to be down on mph. And if they run the same mph, supercharged cars tend to be quicker.
Re: PROCHARGER VS. TURBO [Re: dizuster] #1340123
11/26/12 10:29 PM
11/26/12 10:29 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I do put it on the 2 step at 3500. the fact is i can do it at will without a special *Staging* procedure.
BUT whats really funny is all i hear is talk about how slow my car is from the turbo guys yet for 4 years i haven't seen one get around it?
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: PROCHARGER VS. TURBO [Re: bigtimeauto] #1340124
11/27/12 11:53 AM
11/27/12 11:53 AM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
Bigtime your combo is real similar to what I would like to build if I could sell my N/A stuff.I wish I had my old 572 stuff back that I ran back in 03 I would have a F2 on it blowthru deal.Ive hinted around the idea about crank driven F2 on my W8 stuff,but would rather do 540 to 572 wedge or Hemi.
Whats the best ET you have run with that thing??
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: PROCHARGER VS. TURBO [Re: bigtimeauto] #1340125
11/27/12 12:29 PM
11/27/12 12:29 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
well only showin up to one race a year makes it hard for the Turbo cars to guess where you are or are NOT gonna show up to
Re: PROCHARGER VS. TURBO [Re: FASTFISH420] #1340126
11/27/12 12:31 PM
11/27/12 12:31 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
He went 5.20s at indy....I think he has been a touch faster.... he is still sleepin
Re: PROCHARGER VS. TURBO [Re: joshking440] #1340127
11/27/12 02:15 PM
11/27/12 02:15 PM
San Angelo, Texas
W8n2DustU Offline
W8n2DustU  Offline
San Angelo, Texas
I've ran both in the Duster. Never got the turbo sorted out though. Did figure out after it was to late that my AMS 1000 had a broken internal wire that would not allow me to make boost. Anyhow I was able to run a 5.21@140 weighing in at 3263# with a 360" W8 motor. This was at an altitude of 3758' corrected.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: PROCHARGER VS. TURBO [Re: MIKES_DUSTER] #1340128
11/27/12 02:39 PM
11/27/12 02:39 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Streetcar=turbo....all out racecar= big procharger,just attend a x275 event and you'll see why.
Re: PROCHARGER VS. TURBO [Re: W8n2DustU] #1340129
11/27/12 02:39 PM
11/27/12 02:39 PM
Finland
mopar396 Offline
mopar396  Offline
Finland
366 R3 blowthru no coolers pump E85 with procharger
Best with too tight converter on loose airport track 4.94@147
http://www.youtube.com/watch?v=ZsgqG9c23aY&feature=plcp
MOPAR OR NO CAR
Re: PROCHARGER VS. TURBO [Re: HEMIFRED] #1340130
11/27/12 03:37 PM
11/27/12 03:37 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
blowers take 10% of your power to turn them . turbocharger uses none
Not quite true.
Re: PROCHARGER VS. TURBO [Re: MoparBilly] #1340131
11/27/12 03:48 PM
11/27/12 03:48 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Great question Mike!
The technology race between these two is hard to keep up with, and I'm sure the answer probably reflects those advancements, and the individual application, as well as the persons previous experiences.
I'm just an old nitrous, carb dinasour, so all this stuff is beyond me, but having just attended both Drag Week, and the Street Car Super Nationals, it appears to me that the Turbo Cars have the upper hand. All the rides perpetuating that feeling however, are top flight, no expense spared, best tuners in the biz, so I'm not sure that's the case for the common man!
Qualifying in 10.5 Outlaw at SCSN
Doug Sikora Procharged Hemi Mustang 6.350-226.54
Mike Murillo TT Mustang 6.354-235.39
Billy Glidden Nitrous Mustang 6.45-217.21
Sikora's BAE equipped Stang: The piping appears to be a bit larger than Bigtime Auto's
We've had this car with a SBF/nitrous, a SBF/F3 135 Procharger, SBF/ twin Precision 88's and now a BAE with a 136 Procharger. This combo is hands down the best, fastest and quickest of the 4. We were originally going with twins and the BAE but Doug and I decided it would be more fun and much more consistent with the 136. Our best runs to date were a 6.346 ET and 229.70 MPH speed. Our goal is to get the car into the 20's. I believe that's not too far down the road.
Driving a turbo car at the race track is much more challenging than driving a supercharged car but for the street the turbo is probably the better option.
Re: PROCHARGER VS. TURBO [Re: Crizila] #1340132
11/27/12 05:25 PM
11/27/12 05:25 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I was always told a Turbo is free HP since its fed by exhaust, but builds a lot of heat, and the chargers eithe roots or snail are crankshaft driven and in turn require hp loss to spin, but dont build nearly the heat. The charger systems have come along ways with built in intercoolers, and such, but the turbo also has had some serious upgrades like ball bearings, variable veigns, and such.
Id still LOVE to boost the Demon, but the 10.8 compression will require a lot of reworking the engine.
Re: PROCHARGER VS. TURBO [Re: Moparnut426] #1340133
11/27/12 05:37 PM
11/27/12 05:37 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
A good tune and that 10.8:1 would not be an issue
Re: PROCHARGER VS. TURBO [Re: joshking440] #1340134
11/27/12 07:00 PM
11/27/12 07:00 PM
Moparnut426 Offline
Moparnut426  Offline
Stop telling me such things! I dont need to hear that kind of crap.
Re: PROCHARGER VS. TURBO [Re: Moparnut426] #1340135
11/27/12 08:38 PM
11/27/12 08:38 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Turbos block up the exhaust so they are not free either.
10.8 is no problem, intercooled gas, c 16 no intercooler or e85 would be fine.
Re: PROCHARGER VS. TURBO [Re: Moparnut426] #1340136
11/27/12 10:52 PM
11/27/12 10:52 PM
Az
Crizila Offline
Crizila  Offline
Az
A few of the things that made me go with a Procharger ( centrifugal blower ) verses a turbo are: stand alone lube system, less heat issues ( inner cooler ), exhaust plumbing, Staging issues ( reads consistancy, spool up, exhaust heat ), Lube line plumbing, oil temp issues ( I'm already running a filled block ). Generally, the centrifugal blower system appeared to be a lower maintenance system. The "kit" I bought was very close to a true "bolt on " system. I had already prepped for it though by loosing the P/S and P/B systems from my car. I also have a car with a "ballroom sized" engine compartment.
Fastest 300
Re: PROCHARGER VS. TURBO [Re: joshking440] #1340137
11/27/12 11:13 PM
11/27/12 11:13 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
went 5.15 at indy with the slow procharged street car
Page 3 of 4 1 2 3 4
