Black out areas on a 71 charger rt #1339570
11/22/12 07:21 PM
11/22/12 07:21 PM
Wahoo Nebr
vette1986 Offline OP
Wahoo Nebr
Well my car is finally going in for color tomorrow and I want to make sure the body shop shots the areas correctly. are their areas that need to be blacked out behind the grille or any other spots that should be blacked out or should it all be color? thanks
1969.5 A12 Bee EV2
1971 Charger RT
1973 Duster tubbed 500 low deck 10.90 monster
3 440 polara vert projects
Re: Black out areas on a 71 charger rt [Re: vette1986] #1339571
11/22/12 09:00 PM
11/22/12 09:00 PM
Chilly Northern, Minn.
71 Charger R/T Offline
Here's what Chrysler had to say..........
My car didn't have such a clearly defined cut-off at the upper radiator support, it looked like this.....
so I reproduced it as best I could like this.....
Re: Black out areas on a 71 charger rt [Re: 71 Charger R/T] #1339572
11/22/12 09:19 PM
11/22/12 09:19 PM
Here's another car for reference (not mine)
And here's a Hemi survivor car....... the whole upper radiator saddle is black.
Re: Black out areas on a 71 charger rt [Re: 71 Charger R/T] #1339573
11/24/12 03:33 AM
11/24/12 03:33 AM
minnarusta
TX9H6E4CUDA Offline
TX9H6E4CUDA  Offline
minnarusta
Well I know there is a black out panel on the inside of the doors near the rear edge. Ill take pictures of my original paint car that sat since 1979.
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Black out areas on a 71 charger rt [Re: TX9H6E4CUDA] #1339574
11/26/12 08:34 PM
11/26/12 08:34 PM
You are very correct! I didn't even think of that. looks like black from the seal gasket in...........
Re: Black out areas on a 71 charger rt [Re: 71 Charger R/T] #1339575
11/26/12 09:38 PM
11/26/12 09:38 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I'm sure you guys know that the door gets painted what ever color the door panels are. If the car has white interior the door gets painted white as well.
As far as black out goes, don't forget the lower lip on the front of the hood. Gets done with a brush.
Re: Black out areas on a 71 charger rt [Re: scatpacktom] #1339576
11/26/12 09:43 PM
11/26/12 09:43 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Also, don't forget the often overlooked part of the hood. The vertical pinchweld at the leading edge is also painted black along with the portion of the fenders behind the bumper... You can see here on my former survivor '71 Charger R/T what I'm talking about.
Troy
Houston Mopar Connection Club
Re: Black out areas on a 71 charger rt [Re: scatpacktom] #1339577
11/27/12 02:18 AM
11/27/12 02:18 AM
I don't mean to be contrary, but I beg to differ! My car is a white interior car (factory) and the doors are painted black (original). I think that would be true on second gen's but not what I'm seeing on third gen's.
Re: Black out areas on a 71 charger rt [Re: hemi68charger] #1339578
11/27/12 08:30 AM
11/27/12 08:30 AM
MA
steve70 Offline
steve70  Offline
MA
Does anyone have a more detailed picture of the hood blackout?
1970 Challenger T/A 4 speed
Re: Black out areas on a 71 charger rt [Re: steve70] #1339579
11/27/12 09:44 AM
11/27/12 09:44 AM
western australia
1cuda Offline
1cuda  Offline
western australia
you will also find the interior color door area was painted first directly over the primer and then masked off before the body color went on. interesting about the white interior car with black on the door area-i know the 69 chargers had interior color there but the 3rd gen cars? someone have details on this?
all the best
frank.
Re: Black out areas on a 71 charger rt [Re: 71 Charger R/T] #1339580
11/27/12 10:18 AM
11/27/12 10:18 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I don't know what to say other than "That's Chrysler for ya" My 71 Super Bee that is factory white interior had the doors painted white. I'm sure if I looked around the garages/barns I could take some convincing pictures.
Another location that comes to mind that gets blacked out is the tab on the trailing edge of the fender where there is the strut that goes to the firewall. Also done with a brush
Re: Black out areas on a 71 charger rt [Re: 1cuda] #1339581
11/27/12 10:18 AM
11/27/12 10:18 AM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
I previously owned two 1971 Chargers both with factory white interior and both were painted black in the rear door frame area. Both fender tags had the code TX9 in the door frame color area just before the interior upholstry color code. Black and white interior cars are the only ones I've found to have black door frame paint (on 1971 Chargers anyways)
Re: Black out areas on a 71 charger rt [Re: steve70] #1339582
11/27/12 10:20 AM
11/27/12 10:20 AM
Houston, Tx
Houston, Tx
Here's a photopage from Johnny's 71 webpage. www.71superbee.com
In the below link, you'll see the blacked out portion of the hood. I will try and find the pictures of my '71. Also, don't forget the blacked out treatment of the pinch weld down the length of the rocker panel to floor pan.
http://www.71superbee.com/Eddie_Margosian/GB5/#pop01
http://www.71superbee.com/71ChargerRTRegistry/WS23V1A129300/#pop01
Troy
Re: Black out areas on a 71 charger rt [Re: hemi68charger] #1339583
11/27/12 10:35 AM
11/27/12 10:35 AM
MA
steve70 Offline
steve70  Offline
MA
Thanks Troy!
Re: Black out areas on a 71 charger rt [Re: steve70] #1339584
11/27/12 10:53 AM
11/27/12 10:53 AM
Houston, Tx
Houston, Tx
Thanks Troy!
No problem... And if you want to be as close to OEM as possible, the blacked out treatment on the hood's leading edge AND the rocker pinch was actually done with a brush. On my survivor, I could still see the brush marks..
Troy
Re: Black out areas on a 71 charger rt [Re: hemi68charger] #1339585
11/27/12 12:50 PM
11/27/12 12:50 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Here is a good shot from the "Motor Trend car" owned by Tim Wellborn. It's one of the best examples you can find on the Net I think.
http://www.71superbee.com/Tim_Wellborn/EL5/image_15.html
Re: Black out areas on a 71 charger rt [Re: scatpacktom] #1339586
11/27/12 12:58 PM
11/27/12 12:58 PM
Houston, Tx
Houston, Tx
Perfect... As you can see, it wasn't the "cleanest" of application. In a nutshell, when you look towards the grille from the front, you shouldn't see any body color..... Some people like the "clean" look of fresh paint and not blacking anything out, but I think it distracts from the over all look of the car. The designers knew what they were doing..... Now, remember the fenders got the same treatment just behind the bumper, but only on the top-horizontal portion of the fender recess, not the vertical.
Here's another image..
http://www.71superbee.com/71ChargerRTRegistry/Tim_Wellborn%20FE5/image_32.html
Re: Black out areas on a 71 charger rt [Re: hemi68charger] #1339587
11/27/12 02:18 PM
11/27/12 02:18 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
So in a nut shell, if you car has just come out of the paint shop and is one color these areas would get blacked out.
1) Rad support,fenders(behind grille),hood lip(brush)
2) Fender tab for the firewall strut, rocker pinch weld(both brush)
3) Back of the door (depending on interior color, may not be black)
4) Winshield frame (brush)
Re: Black out areas on a 71 charger rt [Re: hemi68charger] #1339588
11/27/12 07:57 PM
11/27/12 07:57 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Thats too funny Troy.. I owned each of the R/T's in both of the links you posted. I've been thinking of purchasing the Sixpack one back again...for keeps this time.
Re: Black out areas on a 71 charger rt [Re: EL5 71] #1339589
11/28/12 02:10 PM
11/28/12 02:10 PM
Houston, Tx
Houston, Tx
I'd love to get my Survivor '71 back... I would like to contact him again and see "what-if"... It is in New York now... Good luck on the quest to get your v-code back, great car..
Troy
