Bad Lifter and Carbon On Valves After 2000 Miles?? #1339563
11/22/12 06:35 PM
11/22/12 06:35 PM
Out in Left Field, NY
bobs66440 Offline OP
Happy Thanksgiving Everyone!
I had a lifter bleeding down over night on my fresh rebuild, so I yanked the intake and found the offending lifter. It is VERY easy to push down, probably 1/4", while the lifter is on the base of the lobe. That one is obviously bad. The thing is, there are two more on the same side that I can push down, maybe 1/16". All the others are rock hard. No movement at all. Is this normal, or are they getting ready to fail also? I pulled the plugs and they look fine. Some are light brown, Some look almost unused...
Also, looking in the intake ports I see some oily carbon deposits on the valves. It sure seems like a lot for only having 2000 miles on a fresh rebuild with new Stealth heads. Are the seals gone or is some buildup normal??
Re: Bad Lifter and Carbon On Valves After 2000 Miles?? [Re: bobs66440] #1339564
11/22/12 09:52 PM
11/22/12 09:52 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Bad lifters = ticking noise
Bad valve stem seals = major carbon/
build up like you have.
You know what to fix.. oil
I am truckless..
Re: Bad Lifter and Carbon On Valves After 2000 Miles?? [Re: 340SHORTY] #1339565
11/22/12 10:54 PM
11/22/12 10:54 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
go to a small mechanical cam and be done with the hydraulic lifter blues.
Re: Bad Lifter and Carbon On Valves After 2000 Miles?? [Re: bobs66440] #1339566
11/22/12 11:09 PM
11/22/12 11:09 PM
Oil might be getting pulled in thru the lower edge of the valley pan metal gasket up into 1 or more of the intake ports. Improper ring breakin could also be a culprit. Read "breakin secrets" (5 minute read) at www.mototuneusa.com for more info on that subject
Re: Bad Lifter and Carbon On Valves After 2000 Miles?? [Re: RapidRobert] #1339567
11/22/12 11:43 PM
11/22/12 11:43 PM
I had the problem of oil seeping through the intake gasket once before, so when I built the motor I made sure it was well sealed. When I pulled it apart, there was no evidence of seepage so I think it was ok.
Regarding the ring break-in, I'm not sure how that would cause carbon on the valves. The plugs look real good, there is no blow-by and virtually no oil usage.
Re: Bad Lifter and Carbon On Valves After 2000 Miles?? [Re: bobs66440] #1339568
11/23/12 06:07 AM
11/23/12 06:07 AM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
Could the cam overlap be contributing to the deposits?
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: Bad Lifter and Carbon On Valves After 2000 Miles?? [Re: Swedcharger67] #1339569
11/23/12 09:11 AM
11/23/12 09:11 AM
Hi Martin,
Hmmm, I'm not sure how the cam overlap would contribute...
