400 B oil mods #1339115
11/21/12 06:09 PM
11/21/12 06:09 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
It has been a while since I last did this so I need some help. What size do you drill the holes from the mains to the lifter galley? For some reason I thought it was 9/64. Any help would be great!
Re: 400 B oil mods [Re: Biginchmopar] #1339116
11/21/12 08:10 PM
11/21/12 08:10 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
I believe that it's 9/32. Search youtube for a video.
Re: 400 B oil mods [Re: Biginchmopar] #1339117
11/21/12 08:15 PM
11/21/12 08:15 PM
Washington
SuperStock68Dart Offline
Washington
17/64 is what I use.
Re: 400 B oil mods [Re: SuperStock68Dart] #1339118
11/21/12 09:04 PM
11/21/12 09:04 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
http://www.moparts.org/Tech/Archive/bb/12.html
17/64 and 9/32 is the same thing
Re: 400 B oil mods [Re: VernMotor] #1339119
11/21/12 09:08 PM
11/21/12 09:08 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
9/32 is 18/64??
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 400 B oil mods [Re: Von] #1339120
11/21/12 09:20 PM
11/21/12 09:20 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
LOL close enuff !! Knew someone would say that ! about .015 diff ? not sure for this app. would be a big deal ? No they are not the same.
Re: 400 B oil mods [Re: VernMotor] #1339121
11/22/12 03:16 AM
11/22/12 03:16 AM
Carson City, Nevada
Carson City, Nevada
Have any of you guys done the freeze plug trick in the back of the block?
I don't think I did that on the last motor I built. It is a solid roller motor.
Thanks for the help!
Re: 400 B oil mods [Re: Biginchmopar] #1339122
11/22/12 09:46 AM
11/22/12 09:46 AM
ill
dennismopar73 Offline
ill
We just tap a hole in the oil pump run a line to back of the block re install where the oil sender is,(other hole), then restrict the top end of the oil galley going to the head we have never lost a bearing
yet
I have done no mods to my current motor,
Re: 400 B oil mods [Re: VernMotor] #1339123
11/22/12 10:07 AM
11/22/12 10:07 AM
NC
440Jim Offline
440Jim  Offline
NC
Also, from the rear of the motor, take out the oil galley plug on the drivers side of the motor and push a freeze plug into the bore just past the feed that goes to the oil pressure guage ports. It's a 15/32" I think, I'll have to look at my papers at home. Do this mod only for a solid or roller cam as it blocks the oil off the lifters. You can drill a 0.10" hole in it to let a little bit of oil go through if you want. This mod greatly increases the amount of oil availible for the main and rod bearings.
I believe that plug is 19/32". I just helped a buddy with his B-engine stroker. We found this info in Hensley's Racing Ent. "Little Purple" Book that Herb McCandless wrote. Yeah, it's for solid & roller cams only
An old article written by Herb McCandless, says 19/32".
This keeps oil pressure if a lifter pops out on that side of the engine. For example if a rocker breaks and the pushrod comes loose. This is race only, but you can put a small hole in the plug (0.060"-0.100") if you want some oil besides splash oiling to the lifters on that side.
Re: 400 B oil mods [Re: Biginchmopar] #1339124
11/22/12 03:58 PM
11/22/12 03:58 PM
I have on Hemi motor that had the drivers side oil galley machined higher in the block than the passenger side, it would expose the oil galley at max lift with a old set of non skirted solid roller lifters, I put in a small, can't remember the size now, welsh, freeze plug I ended up having to put two of them in, the first one turned sideways after running the car at a couple of races and started pulsing the oil pressure at idle, the second one never turned
Re: 400 B oil mods [Re: Cab_Burge] #1339125
11/22/12 04:16 PM
11/22/12 04:16 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
When I worked in the block department at Keith Black's I reamed (don't remember the size) the drivers side lifter galley from the rear (don't remember how deep) and drove in a little aluminum plug to block off that side of the lifter galley. I don't see those plugs for sale anymore, don't know why. It thought it was a good thing.
2011 Drag Pak Challenger
