Hedman B/RB shorty headers, 383 Challenger... #1338870
11/21/12 11:38 AM
11/21/12 11:38 AM
the frozen wastes...
Pale_Roader Offline OP
Swears too much
Swears too much
Part 2 ov my welfare warrior quest. Headers.
70 Challenger, stock 67 383, 4-speed, NO power options at all. Stock suspension. Will be using a Lakewood skattershield and block saver though.
I have a barely used set o Hedman shorties for a big block B/E car. How bad are they performance-wise over the usual long-tubes (Hooker Comps lets say)? Closer to HP manifolds in performance? closer to longtubes? The exhaust behind them will not be a limiting factor... at all.
Any issues with installation in my combo? I cannot think ov an easier E-body big block install than mine...
How about changing spark plugs? They've GOT to be better than Hooker Comps...
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: Pale_Roader] #1338871
11/21/12 11:59 AM
11/21/12 11:59 AM
Hightstown, NJ
njdevil2 Offline
njdevil2  Offline
Hightstown, NJ
I was thinking of doing this on my roadrunner. I don't need the hassle of long tubes. I beileve the loss over long tube is 4-8% hp. I'm not sure of torque. You definitly need the mini-starter. I'm not clear if there is a problem with power steering, which I have.
Any one else have more info on this?
1970 road runner Convertible
1 of 179
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: njdevil2] #1338872
11/22/12 09:15 PM
11/22/12 09:15 PM
Swears too much
Swears too much
Soooo.... not a popular item then...???
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: Pale_Roader] #1338873
11/22/12 09:43 PM
11/22/12 09:43 PM
Hedman 78030.
Fit great, cheap ($159.00 through summit), and virtually drop in.
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: Pale_Roader] #1338874
11/23/12 12:00 AM
11/23/12 12:00 AM
Canada
WO23Coronet Online content
WO23Coronet  Online Content
Canada
Dulcich did a test on these exact headers, HP manifolds vs Hedman shorties vs long tubes. As expected the shorties fell in between the manifolds and long tubes. Do a search on the Mopar Muscle site, it's a good read
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: WO23Coronet] #1338875
11/23/12 12:12 AM
11/23/12 12:12 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I have them on mine. Love them and they still look great. And, I installed the engine with them mounted! Lots of clearance and great access to the plugs too
As far as performance goes, they seem to be great, though I haven't done a side by side comparison with long tubes or manifolds. I did read the comparison mentioned a while back and they fell right in between, maybe a little closer to the long tubes than the manifolds.
They clear the PS box, but just barely. I dimpled the driver's side one where it was close just in case.
The ease of installation and access to the plugs are infinitely better than manifolds and especially long tube headers of course. Whatever you may lose over the long tubes, I don't think would be very noticeable on a street car and the convenience benefits definitely outweigh any loss in my opinion. I will definitely use them again...
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: bobs66440] #1338876
11/23/12 12:26 AM
11/23/12 12:26 AM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
I see your tube is dented where the power steering box is. How much did you have to dent it?
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: bordin34] #1338877
11/23/12 12:48 AM
11/23/12 12:48 AM
bobs66440 Offline
bobs66440  Offline
It wasn't actually hitting the PS box, but it was really close. I just dimpled it in two places where it was close just in case. I heated it with a torch and pushed it in a little , maybe 1/8".
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: bobs66440] #1338878
11/23/12 12:52 AM
11/23/12 12:52 AM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
Thanks. I have a set I am planning on putting on my 440 Power Steering Charger tomorrow. I got tired of the full length headers getting in the way of everything.
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: bordin34] #1338879
11/23/12 12:57 AM
11/23/12 12:57 AM
Canada
Canada
Here's the article http://www.moparmusclemagazine.com/techarticles/mopp_0106_manifolds_vs_headers/viewall.html
It's on a fairly stout 440 but it should give u an idea
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: WO23Coronet] #1338880
11/23/12 12:06 PM
11/23/12 12:06 PM
Swears too much
Swears too much
Cool. I either have that magazine and its lost in the stack, or i have an older one that did the same test with the shorties, manifolds and longtubes. I wasn't sure anyone else remembered. I should know better on this site. Haha
The shorties did better than i remembered. They give up quite a bit in the TQ dept, but i think the difference would be less on a mild 383 than a stout 440. The smaller primaries are better suited (though i'd still like 1 7/8") to a 383.
I wonder if the collector treatment is cause for much ov that loss? Looking closely at my set i've never liked how the collectors looked. They scream flow-impediment. Depending on how much room i have i was contemplating modifying them with a full size collector so all the primaries dont just jam into a tiny mass in front ov the 2 1/2" hole.
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: WO23Coronet] #1338881
11/23/12 12:10 PM
11/23/12 12:10 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Kudos to Hedman for making another option for mopar! The magazine dyno test was done on a pretty hot 440- 500hp plus. (mild by some peoples definition but even an old school HP 440, 509 cam, Torker intake, DP Holley ect did not make 500hp) On a milder 440 than the one tested the shorties will not have such a handicap to the long tubes. I say fit the shorties- ding where need then remove and have ceramic coated. I had a four into two GS1000 Suzuki exhaust system ceramic coated in satin black for $150. Place is only 25 miles from me to boot.
Keep old mopars alive.
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: 2boltmain] #1338882
11/24/12 10:25 AM
11/24/12 10:25 AM
Swears too much
Swears too much
Hmmm... more and more these look like a great temp solution until i can afford real headers. I might just modify those collectors though... why not?
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: Pale_Roader] #1338883
11/24/12 01:38 PM
11/24/12 01:38 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
I put the shortys on my 73 440 with power steering.
I had to dent the first tube on the drivers side a decent amount. I also needed a small ding on the last tube on the drivers side.
The passenger side needed nothing.
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: bobs66440] #1338884
11/24/12 03:18 PM
11/24/12 03:18 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The one thing I try to point out is while they give up a little performance wise to long tubes the first time you bottom out those long tubes what ever advantage they had is no gone... If you like a car that sits up a foot off the ground no problem but I like my cars a little lower than stock....
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: bordin34] #1338885
11/24/12 03:40 PM
11/24/12 03:40 PM
bobs66440 Offline
bobs66440  Offline
Right. Same for me. First and last tube. You will like them though! especially when you have to work around them.
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: bobs66440] #1338886
11/24/12 05:51 PM
11/24/12 05:51 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I like the color of mine...I hope I find some extra cash soon...I have had these Hedman's coated for 4 years now and I havent had the time to bolt them on. I used to have 2 1/8" Hookers on my 70 and I hated the tight clearances. I have the HP Manifolds right now and looking to pick up 10% more power with the swap.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: Pyper70] #1338887
11/24/12 06:30 PM
11/24/12 06:30 PM
After reading this post and the Mopar Muscle article, I ordered a set of the shorties for my 59 413 Coronet. Power steering gearbox is further to the rear on it compared to later B and E bodies, so I think it will clear w/o any problem. Fingers are crossed.
Re: Hedman B/RB shorty headers, 383 Challenger... #1338888
11/24/12 10:49 PM
11/24/12 10:49 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
Spark plug access is nice with them. I can actually see where I am putting the plugs for once.
Re: Hedman B/RB shorty headers, 383 Challenger... [Re: bordin34] #1338889
11/25/12 10:10 AM
11/25/12 10:10 AM
Swears too much
Swears too much
That will be a nice bonus... My Charger had the wider 440, and Hooker Comps, and even with nothing else in the way (manual steering, no accessories) they were an absolute nightmare for plugs. Add to that the crop-duster 440's appetite for them...
Yeah... really dont miss that car.
Challenger, narrower 383, NO accessories at all, smaller headers, and hopefully (fingers crossed) the engine wont burn any oil. I'm already giddy...
