trunk torsion ron question #1338287
11/19/12 10:07 PM
11/19/12 10:07 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
Body shop removed trunk torsion rods to paint car. When it came back, I place the rods back in the car with NEW sliders on the ends. Now when I close the trunk there is a MAJOR popping sound and after about 5 closes, the rod pops out of place and the slider get thrown off. What is wrong with this?
Re: trunk torsion ron question [Re: TrueTripleX] #1338288
11/19/12 10:15 PM
11/19/12 10:15 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
a pic of how its set up would be VERY helpful.
Re: trunk torsion ron question [Re: bonefish] #1338289
11/19/12 11:16 PM
11/19/12 11:16 PM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
did you grease the sliders ?
Re: trunk torsion ron question [Re: 2abodymcodes] #1338290
11/19/12 11:32 PM
11/19/12 11:32 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
A pic would help. Sounds like the rods are in correctly.
Yes grease the sliders but that shouldn't make the rods pop out.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: trunk torsion ron question [Re: moparmarks] #1338291
11/22/12 01:50 PM
11/22/12 01:50 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Not sure if this helps, but one rod is Left, and one is Right. They aren't interchangeable. Here's a photo of '69 A body rods with non-slider application. The rod on the left of the photo is a Left rod.
Re: trunk torsion ron question [Re: kentj340] #1338292
11/22/12 01:59 PM
11/22/12 01:59 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Factory assembly, left side, of a 69 A body with non-slider application. (This is a one-owner car never taken apart until after this photo.)
