Should This Black Stuff Be Coming Out Of My Voltage Regulator? #1337924
11/19/12 05:28 PM
11/19/12 05:28 PM
Costa Mesa, California
michaelphbarnett Offline OP
Should this black stuff be coming out of my voltage regulator?
Re: Should This Black Stuff Be Coming Out Of My Voltage Regulator? [Re: michaelphbarnett] #1337925
11/19/12 05:32 PM
11/19/12 05:32 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
No. Looks like it was overheated. Could be the rust and the heat taking the paint off. Change it.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Should This Black Stuff Be Coming Out Of My Voltage Regulator? [Re: michaelphbarnett] #1337926
11/19/12 07:23 PM
11/19/12 07:23 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Be sure it has a good ground. The only thing that grounds these are the mount bolts. I think they lose ground through over the years and overheat.Scrape the back side and a place on the firewall.
Re: Should This Black Stuff Be Coming Out Of My Voltage Regulator? [Re: michaelphbarnett] #1337927
11/19/12 10:33 PM
11/19/12 10:33 PM
Posting from 1893 in NW FL
TheBlueBeast Offline
No but many Chevy guys thinks it is correct.
Re: Should This Black Stuff Be Coming Out Of My Voltage Regulator? [Re: TheBlueBeast] #1337928
11/19/12 10:36 PM
11/19/12 10:36 PM
amxautox Offline
amxautox  Offline
Chevy guys wouldn't even know it's leaking, with their dumb black engine compartments regardless what color their car is.
Tom
author unknown
Re: Should This Black Stuff Be Coming Out Of My Voltage Regulator? [Re: amxautox] #1337929
11/19/12 10:38 PM
11/19/12 10:38 PM
Hey Tom,
Mrs TBB just complimented the AMX.
Re: Should This Black Stuff Be Coming Out Of My Voltage Regulator? [Re: TheBlueBeast] #1337930
11/19/12 10:39 PM
11/19/12 10:39 PM
amxautox Offline
amxautox  Offline
Hey Tom,
Tell her Thanks, she has a great eye.
After all, it DOES have blue on it,
and no green.
Tom
author unknown
Re: Should This Black Stuff Be Coming Out Of My Voltage Regulator? [Re: amxautox] #1337931
11/20/12 06:34 AM
11/20/12 06:34 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Seen that happen to an Orange Box a few times...You need to make a clean chassis ground with stainless cable. If you can, put a spacer behind it, the ECU's had a dog leg spacer on 72 & Up. Maybe you can make one out of galvanized steel and make it look better
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Should This Black Stuff Be Coming Out Of My Voltage Regulator? [Re: Pyper70] #1337932
11/20/12 09:29 AM
11/20/12 09:29 AM
federal way, WA
74chargr Offline
74chargr  Offline
federal way, WA
FYI you shouldn't use Stainless on electrical connections. It is resistive and can cause problems. If you want to get fancy use some nickel plated wire as that won't corrode and the nickel is conductive.
74 Charger SE 87 Shelby Lancer 80 1 ton bread box 71 Duster rest in pieces
Re: Should This Black Stuff Be Coming Out Of My Voltage Regulator? [Re: 74chargr] #1337933
11/20/12 12:26 PM
11/20/12 12:26 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I dunno, never had a problem...I have one from the Starter to the engine, starter to chassis, engine to chassis...still on there after 12 yrs and never had any grounding issues
Re: Should This Black Stuff Be Coming Out Of My Voltage Regulator? [Re: michaelphbarnett] #1337934
11/20/12 03:35 PM
11/20/12 03:35 PM
IMGTX Offline
IMGTX  Offline
That is not uncommon. Ma Mopar filled the back of the ECU's and Voltage Regulator's with an epoxy like material to protect and seal the circuitry.
Often the material degrades with age and oozes down the firewall. It seems to be related to time more than anything else because I have seen them do that on cars that haven't even been running in 20 years.
Eventually the circuits will be exposed and fail but that may take years.
I'd replace it to make sure that goop doesn't make any more of a mess.
