Anybody know what this trans crossmember goes to ? #1337676
11/19/12 11:13 AM
11/19/12 11:13 AM
Winchester, In
tippytoe Offline OP
tippytoe  Offline OP
Winchester, In
I was cleaning out the garage yesterday & stumbled across this trans crossmember/mount. The trans mount has a large through-style bolt rather than the small stud & nut like am used to seeing on 68-70 b-bodys. I have seen these before but its been so long ago, I can't remember what vehicles had these (darn old age !). The crossmember was very dirty so I couldnt read the part number. Any help would be appreciated.
Re: Anybody know what this trans crossmember goes to ? [Re: tippytoe] #1337677
11/19/12 11:28 AM
11/19/12 11:28 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Looks to be a 71/2B-E all trannys. What is the spacing of the mounting bolt holes?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Anybody know what this trans crossmember goes to ? [Re: moparmarks] #1337678
11/19/12 11:35 AM
11/19/12 11:35 AM
Winchester, In
tippytoe Offline OP
tippytoe  Offline OP
Winchester, In
I will have to check. I took it to the shop & forgot to bring it back home ( Darn memory again ! ).
Re: Anybody know what this trans crossmember goes to ? [Re: moparmarks] #1337679
11/20/12 01:35 PM
11/20/12 01:35 PM
Winchester, In
tippytoe Offline OP
tippytoe  Offline OP
Winchester, In
The two outer mounting holes are 18 inches apart (measured center to center of each hole). The inner mounting holes are 8&1/2 inches apart (center to center). The distance from the outer hole to the inner is roughly 5&3/4 inches (center to center).
