Gen III Hemi and auto tranny in e-body?
#1336964
11/18/12 09:37 AM
11/18/12 09:37 AM
Posts: 523 Right here
HP2
Right here
We have seen many gen 3 conversions now, but I can't recall seeing anything but manual. I want to go automatic and it would be nice to use the matched original 5-speed auto tranny in my 70 cuda vert. I have the engine but no tranny yet. Before I get one I need to know if it will be room for it.
70 W100 Power Wagon. 318 4-spd 70 Sport Fury 440 2dr HT 71 Duster 340 71 Charger Super Bee - 383/727 72 Charger "Sabotage" - 440/727 - Street/Strip 78 Warlock in beautiful patina
Re: Gen III Hemi and auto tranny in e-body?
[Re: HP2]
#1336965
11/18/12 12:36 PM
11/18/12 12:36 PM
Posts: 8,492 Candler,NC / Myrtle Beach, SC
JDMopar
If you want a new 5 spd automatic, the best and easiest to use is a 545RFE out of a 2wd pickup or Durango. They are the only ones that have a slip yoke tailshaft, and can be run by the ECU from an 05 Dodge pickup. It's a BIG transmission, and it will require cutting the floor pan and torsion bar crossmember. It's not a swap that's for the faint of heart, but can end up nice. I'm putting a 5.7 Hemi and a 545RFE in a 70 Duster. If you don't want to cut the floor pan and crossmember, you could use a 518 automatic. They will bolt straight to a Gen3 Hemi with a thin spacer, and there is a flexplate available for the Gen3 Hemi to 727/518 convertors. Do lot's of research before plunking down a bunch of money. Good luck.
[Re: Greg Ducato]
#1336971
11/21/12 01:06 PM
11/21/12 01:06 PM
JDMopar
That is on my list of questions to ask Chris Squire about when I call to order my harness. Dakota Digital made a nice gauge cluster for the Duster that was built on the show "Chop,Cut,Rebuild" I want to use the same thing, but I don't remember what they used for a transmission in that car. If that doesn't work out, I'll go to plan B and use an Autometer GPS speedometer. When I talked to Chris at the Mopar Nats this year, he said they about had it worked out on making cruise control work thru the ECU. They were perfecting a tone ring that goes in the tailshaft housing of a 545RFE, and it will send an output signal to the ECU. I would think if there's an output signal, it should work a speedometer also. I'm a good ways away from there yet,so that's kinda on the worry list backburner.
[Re: WO23Coronet]
#1336973
11/22/12 01:57 PM
11/22/12 01:57 PM
HP2
Right here
Can you specify where and how the tunnel needs to be modified? The gas pedal is very close to the tunnel, and also far left. IS the 545RFE also high so the top of the tunnel needs to be modified?
[Re: HP2]
#1336974
11/22/12 02:29 PM
11/22/12 02:29 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
There are a lot of threads about the trans tunnel mod, but most of them are installs of the 518 & 46 RH etc.
We need some more picture essays of the project for the Gen 3 trans install if you want to bother with it.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: HP2]
#1336975
11/23/12 01:21 AM
11/23/12 01:21 AM
JDMopar
I don't have any pics yet, as I am not that far along in my swap. I have seen pics on the For A Bodies Only Mopar forum that show the tunnel mods. You have to split it up the middle, and also down each side to widen it out. It also has to be made a little taller. You also have to cut the top arch out of the torsion bar crossmember, and tie it back together with newly shaped steel after you get it cut wide enough for the 545 to fit. I plan on cutting the tunnel out around the transmission area, cutting the torsion bar crossmember, making a new transmission mount, and then making a new arch for the torsion bar crossmember. Then I will make the tunnel fit all that, and give adequate clearance around the 545.Nothing a few hours, a sawzall, and a mig welder can't remedy! No need to worry about the gas pedal, as you'll have to change that to a drive by wire pedal from a Dodge truck anyway.Gen3 Hemis don't use a throttle cable.
