Gen III Hemi and auto tranny in e-body? #1336964
11/18/12 09:37 AM
11/18/12 09:37 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
We have seen many gen 3 conversions now, but I can't recall seeing anything but manual. I want to go automatic and it would be nice to use the matched original 5-speed auto tranny in my 70 cuda vert. I have the engine but no tranny yet. Before I get one I need to know if it will be room for it.
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: Gen III Hemi and auto tranny in e-body? [Re: HP2] #1336965
11/18/12 12:36 PM
11/18/12 12:36 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
If you want a new 5 spd automatic, the best and easiest to use is a 545RFE out of a 2wd pickup or Durango. They are the only ones that have a slip yoke tailshaft, and can be run by the ECU from an 05 Dodge pickup. It's a BIG transmission, and it will require cutting the floor pan and torsion bar crossmember. It's not a swap that's for the faint of heart, but can end up nice. I'm putting a 5.7 Hemi and a 545RFE in a 70 Duster. If you don't want to cut the floor pan and crossmember, you could use a 518 automatic. They will bolt straight to a Gen3 Hemi with a thin spacer, and there is a flexplate available for the Gen3 Hemi to 727/518 convertors. Do lot's of research before plunking down a bunch of money. Good luck.
Re: Gen III Hemi and auto tranny in e-body? [Re: JDMopar] #1336966
11/19/12 11:44 AM
11/19/12 11:44 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
It looks like I still can buy the tranny from the Challenger that I got the engine from.
Is the biggest problem with the SRT8 tranny that it has no slip yoke?
Is it as big as the 545RFE?
I have also considered the 518, but rather want a modern transmission with all the benefits. Especially if I can used the matched one, but I don't really like to cut the tunnel and floors too much...
71 Duster 340
Re: Gen III Hemi and auto tranny in e-body? [Re: HP2] #1336967
11/19/12 06:11 PM
11/19/12 06:11 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
That tranny (SRT one) is a NAG1, it's a Mercedes tranny, completely different beast. From what I've read on here from another members post is that the NAG1 needs some sort of feedback from the ABS system to function properly because of the traction control system, so you would need to incorporate that as well, which doesn't sound fun. Go with the 545RFE, they're pretty bullet proof
Re: Gen III Hemi and auto tranny in e-body? [Re: WO23Coronet] #1336968
11/19/12 11:34 PM
11/19/12 11:34 PM
JDMopar Offline
JDMopar  Offline
WO23 has it right. The NAG1 has to take the input from all 4 sensors in the ABS and send that to the computer. It averages out the 4 readings to determine speed, and that is how the computer tells the transmission when to shift. That's kind of a gross oversimplification, but by all accounts I've heard...a NAG1 is a pain in the a$$ to get to work in an old car. If I can get to Photobucket, I will post pics of the 2 transmissions.
Re: Gen III Hemi and auto tranny in e-body? [Re: JDMopar] #1336969
11/19/12 11:44 PM
11/19/12 11:44 PM
JDMopar Offline
JDMopar  Offline
Here is my Hemi, and my 545RFE. I don't have any pics of the NAG1 that came attached to my motor. I deleted them after I sold it.
Re: Gen III Hemi and auto tranny in e-body? [Re: JDMopar] #1336970
11/20/12 01:51 PM
11/20/12 01:51 PM
Weatherford Texas
Greg Ducato Offline
Greg Ducato  Offline
Weatherford Texas
JD, what are your plans for the speedometer since the trans has no output for a mechanical cable drive.
Re: Gen III Hemi and auto tranny in e-body? [Re: Greg Ducato] #1336971
11/21/12 01:06 PM
11/21/12 01:06 PM
JDMopar Offline
JDMopar  Offline
That is on my list of questions to ask Chris Squire about when I call to order my harness. Dakota Digital made a nice gauge cluster for the Duster that was built on the show "Chop,Cut,Rebuild" I want to use the same thing, but I don't remember what they used for a transmission in that car. If that doesn't work out, I'll go to plan B and use an Autometer GPS speedometer. When I talked to Chris at the Mopar Nats this year, he said they about had it worked out on making cruise control work thru the ECU. They were perfecting a tone ring that goes in the tailshaft housing of a 545RFE, and it will send an output signal to the ECU. I would think if there's an output signal, it should work a speedometer also. I'm a good ways away from there yet,so that's kinda on the worry list backburner.
Re: Gen III Hemi and auto tranny in e-body? [Re: JDMopar] #1336972
11/21/12 08:35 PM
11/21/12 08:35 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Also, if all you can find is a 4x4 tranny, there is a kit out there that supplies a tail shaft and all the necessary parts to convert it, can't remember off the top of my head who sells it though
Re: Gen III Hemi and auto tranny in e-body? [Re: WO23Coronet] #1336973
11/22/12 01:57 PM
11/22/12 01:57 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Can you specify where and how the tunnel needs to be modified?
The gas pedal is very close to the tunnel, and also far left.
IS the 545RFE also high so the top of the tunnel needs to be modified?
71 Duster 340
Re: Gen III Hemi and auto tranny in e-body? [Re: HP2] #1336974
11/22/12 02:29 PM
11/22/12 02:29 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
There are a lot of threads about the trans tunnel mod, but most of them are installs of the 518 & 46 RH etc.
We need some more picture essays of the project for the Gen 3 trans install if you want to bother with it.
Re: Gen III Hemi and auto tranny in e-body? [Re: HP2] #1336975
11/23/12 01:21 AM
11/23/12 01:21 AM
JDMopar Offline
JDMopar  Offline
I don't have any pics yet, as I am not that far along in my swap. I have seen pics on the For A Bodies Only Mopar forum that show the tunnel mods. You have to split it up the middle, and also down each side to widen it out. It also has to be made a little taller. You also have to cut the top arch out of the torsion bar crossmember, and tie it back together with newly shaped steel after you get it cut wide enough for the 545 to fit. I plan on cutting the tunnel out around the transmission area, cutting the torsion bar crossmember, making a new transmission mount, and then making a new arch for the torsion bar crossmember. Then I will make the tunnel fit all that, and give adequate clearance around the 545.Nothing a few hours, a sawzall, and a mig welder can't remedy! No need to worry about the gas pedal, as you'll have to change that to a drive by wire pedal from a Dodge truck anyway.Gen3 Hemis don't use a throttle cable.
