Re: Street/Strip converter help.
[Re: 383man]
#1336422
11/17/12 05:10 PM
11/17/12 05:10 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Another vote for Dynamic. I am very happy with the 9-1/2" converter Shaun spec'd for my car. I'm sure that Ultimate, PTC or a few other companies could also offer great options. The key is to call the company, and have them build one specific to your combo.
[Re: DaKuda]
#1336423
11/17/12 10:23 PM
11/17/12 10:23 PM
Posts: 12,138 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
When you compare prices, PTC is hard to beat. They have built several for me and they work.
I have one now that will flash 4,000 or 4,100 at the track, but will cruise at 2,800-3,000 with out too much heat.
They are Mopar guys at PTC that know their stuff.
Master, again and still
[Re: goldmember]
#1336425
11/18/12 02:32 AM
11/18/12 02:32 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Yes there are some good converter companies out there. I love the street/strip Dynamic I use as it will flash about 4200 and I cruise the highway all the time in the 3000 to 3300 area. I run the highway for about 90 miles like that driving to Carlisle and have never had problems as it cruises great like that. I also agree to call who ever you decide on and have them build it for your combo. You will have to give them all the combo specs. I used Turbo Action before also which also worked great for me. I just decided to go with Dynamic on my 63 since they are very close to me and were cheaper then the Turbo Action. I was glad I used the Dynamic as I could pick it up instead of having it shipped to me and it worked as good as the T/A. As was stated there is a few other real good converter companies out there but I really do like the Dynamic and Turbo Action converters. Ron
[Re: DaveRS23]
#1336428
11/18/12 08:06 AM
11/18/12 08:06 AM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
How much heat is too much? I see 135 degrees in the pan after a 25 mile cruise. How much is too much?
[Re: davenc]
#1336433
11/18/12 06:18 PM
11/18/12 06:18 PM
Posts: 412 Hampton Va
gtsdon
Hampton Va
davenc, that is not what I was trying to say. My old 340 engine and Turbo Action converter combo went 1.5- 60 foots and ran high 11s. New engine is a Shady Dell prepped 418 that should run high 10s in my car. Best 60 foot with new engine and PTC Converter is high 1.7s and 11:40 et.
Yes, I talked to PTC and they said send it back and they will make it right. My point was- it sucks that I have to pull the headers exhaust, transmission and whatever else out of the car and send the converter back just to get what I originally asked for. Not to mention the cost of fluids and shipping. Hopefully, they can get it right the second time. Not trying to bash or make anyone look bad, just posting about the issue I am currently going through.
[Re: Hemi ragtop]
#1336434
11/18/12 06:44 PM
11/18/12 06:44 PM
StealthWedge67
Puyallup, WA
Measuring in the pan, its really tough to say. You're measuring the fluid after its gone through the cooler, but before it cycles through the trans. So all you really know is that your cooler is doing its job, although I'll concede that its probably all relative. I've been told to measure in the "out" line just outside the trans. Set up like this, I typically get a reading of around 175 while warm and cruising. up a long hill, and it jumps to about 200. After a pass, it typically reads about 210. I've been told by Pat Blais (torqueflite guru) that anything under 240 is just fine, @ 250 ATF starts to foam up, so if the needle goes north of 250, pull over. The fluid in your transmission could be way north of 250, but by the time it goes through the cooler and back to the pan, you could be seeing 200? 210? and think its just fine, when in reality its scorching hot in the friction zone. With all that said, most people install the sending unit in the pan, so you're in the majority.
[Re: StealthWedge67]
#1336435
11/19/12 02:39 AM
11/19/12 02:39 AM
Posts: 1,559 Oh
His and Her 69's
Oh
My PTC conv was not any good when I tried to spray NOS as it kept breaking. I would send it back to Kenny, rebuild trans, reinstall rebuilt conv and 2nd NOS pass broke it again. This was his 8" conv and he knew all the spec's and was built for my purpose. Broke it 2 different times, each time when I would hit the NOS. Sent it back, he built me a 9.5", I had told him I SOLD the NOS and it was an all motor deal now, installed it and what a pig the car was, lost .50 in ET, called him and he messed up and built it for NOS, he was sorry and gave me an 8" per John Copes suggestion, I needed the stahl to be 5600 and when it was installed it was 6100. I called and Kenny was Nice about it, wanted to help get it right BUT I was tired of all the issues and taking the trans in and out 4 times in 1 year. I left it in and sold the car a year later. I Like PTC/Kenny but won't go thru that again. Just my 2cents.
