Im sure this has been asked millions of times but its my turn now I guess. Need a converter that does both well but leans a little more to the ProStreet or track side. Does need to be able to drive well though. Dont want a race converter, been there done that. Have always used Turbo Action but open to others. Car is around 3250lbs and is an ex-racecar being put on the street. Will take to the track and spray it every now and then. What size do you guys run for this application? 9 or 10 inch? What is a good stall to shoot for? Will any of the "off the shelf" converters work? I see Jegs has Turbo Actions in the new book.
