Street/Strip converter help. #1336418
11/17/12 10:50 AM
11/17/12 10:50 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Im sure this has been asked millions of times but its my turn now I guess. Need a converter that does both well but leans a little more to the ProStreet or track side. Does need to be able to drive well though. Dont want a race converter, been there done that. Have always used Turbo Action but open to others. Car is around 3250lbs and is an ex-racecar being put on the street. Will take to the track and spray it every now and then. What size do you guys run for this application? 9 or 10 inch? What is a good stall to shoot for? Will any of the "off the shelf" converters work? I see Jegs has Turbo Actions in the new book.
Re: Street/Strip converter help. [Re: DaKuda] #1336419
11/17/12 11:10 AM
11/17/12 11:10 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well Dynamic and Ultimate both make great dual use converters. So does PTC I hear. They seem to have a handle on making them tight for regular driving but at WOT will go to the stall you want for performance!
A little more money but worth it.
Re: Street/Strip converter help. [Re: Dodgem] #1336420
11/17/12 11:32 AM
11/17/12 11:32 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
www.edgeracingconverters.com, Talk to Andre. I have one of their 9.5" converters in my street/strip Dart. It's been 1.38 60' in good air and works great on the street too.
Re: Street/Strip converter help. [Re: justinp61] #1336421
11/17/12 04:09 PM
11/17/12 04:09 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have the Luppo Dynamic 9.5 converter in my 63 and my boys Dart. They work great for us as ours are mostly street cars that might see the track a few times a year. Ron
Re: Street/Strip converter help. [Re: 383man] #1336422
11/17/12 05:10 PM
11/17/12 05:10 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Another vote for Dynamic. I am very happy with the 9-1/2" converter Shaun spec'd for my car. I'm sure that Ultimate, PTC or a few other companies could also offer great options. The key is to call the company, and have them build one specific to your combo.
Re: Street/Strip converter help. [Re: DaKuda] #1336423
11/17/12 10:23 PM
11/17/12 10:23 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
When you compare prices, PTC is hard to beat. They have built several for me and they work.
I have one now that will flash 4,000 or 4,100 at the track, but will cruise at 2,800-3,000 with out too much heat.
They are Mopar guys at PTC that know their stuff.
Master, again and still
Re: Street/Strip converter help. [Re: DaKuda] #1336424
11/17/12 10:49 PM
11/17/12 10:49 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Not enough info to give a recommendation,but I'd call PTC and give them all the info. I use PTC and have for years,but there are other good companies that can build a good converter as well.
Re: Street/Strip converter help. [Re: goldmember] #1336425
11/18/12 02:32 AM
11/18/12 02:32 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes there are some good converter companies out there. I love the street/strip Dynamic I use as it will flash about 4200 and I cruise the highway all the time in the 3000 to 3300 area. I run the highway for about 90 miles like that driving to Carlisle and have never had problems as it cruises great like that. I also agree to call who ever you decide on and have them build it for your combo. You will have to give them all the combo specs. I used Turbo Action before also which also worked great for me. I just decided to go with Dynamic on my 63 since they are very close to me and were cheaper then the Turbo Action. I was glad I used the Dynamic as I could pick it up instead of having it shipped to me and it worked as good as the T/A. As was stated there is a few other real good converter companies out there but I really do like the Dynamic and Turbo Action converters. Ron
Re: Street/Strip converter help. [Re: 383man] #1336426
11/18/12 03:28 AM
11/18/12 03:28 AM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
I have a 9.5 Dynamic too, works great!
Re: Street/Strip converter help. [Re: DaKuda] #1336427
11/18/12 05:12 AM
11/18/12 05:12 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Ultimate can custom build what you want, but they are more expensive than some others. I was leaning towards a 9-1/2" Dynamic because I had an older 10" Dynamic that worked well in my old setup. I talked to Ultimate, and they built me a custom 9" converter that on the street is tighter than my old 10" converter, but will flash stall to 5,000 RPM.
Re: Street/Strip converter help. [Re: DaveRS23] #1336428
11/18/12 08:06 AM
11/18/12 08:06 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
How much heat is too much? I see 135 degrees in the pan after a 25 mile cruise. How much is too much?
Re: Street/Strip converter help. [Re: Hemi ragtop] #1336429
11/18/12 09:51 AM
11/18/12 09:51 AM
Hampton Va
gtsdon Offline
gtsdon  Offline
Hampton Va
I just installed a PTC Converter in my car this fall. The engine builder specified a certain stall speed (4600) as he has built several of the same engine/ transmission combos over the years and knows what works. Gave PTC a call and provided engine, transmission, suspension, tire size, gear etc info to them and was told they would recommend a 3600 converter. I said I wanted a custom 4600 per the builder’s request. Was told it would not be a problem 4600 it is. Got the car running and guess what? Converter will only flash to 3600. Car will only 60’ in the high 1.7 range but runs low 11s. Called PTC to explain what was going on and was told I needed more stall speed (at least 4200). When I told them what stall speed was originally requested (4600) the phone went silent. I now have to pull the transmission out of a car I just got running, pay shipping to and from PTC just to get the stall speed I originally requested.
Sad part is-I removed a (3600) Turbo Action Converter from behind my old 340 that had been in the car for over ten years. Never had an issue driving on the street and performed great at the track. The Turbo Action Converter would click off mid 1.5 60’ and run high 11s all day long.
Re: Street/Strip converter help. [Re: gtsdon] #1336430
11/18/12 11:13 AM
11/18/12 11:13 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Everybody makes mistakes. Kenny is a standup guy. All you can ask is that he make it good. My PTC does exactly what I speced.
Re: Street/Strip converter help. [Re: gtsdon] #1336431
11/18/12 12:08 PM
11/18/12 12:08 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
GTSDon,
Did I read your post right....the car with the TA converter went high 11s, and with the PTC converter went low 11s? Were there any other changes to the car?
Re: Street/Strip converter help. [Re: DaKuda] #1336432
11/18/12 12:15 PM
11/18/12 12:15 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
PTC here. 9.5" 5000 stall.
Re: Street/Strip converter help. [Re: davenc] #1336433
11/18/12 06:18 PM
11/18/12 06:18 PM
Hampton Va
gtsdon Offline
gtsdon  Offline
Hampton Va
davenc, that is not what I was trying to say. My old 340 engine and Turbo Action converter combo went 1.5- 60 foots and ran high 11s. New engine is a Shady Dell prepped 418 that should run high 10s in my car. Best 60 foot with new engine and PTC Converter is high 1.7s and 11:40 et.
Yes, I talked to PTC and they said send it back and they will make it right. My point was- it sucks that I have to pull the headers exhaust, transmission and whatever else out of the car and send the converter back just to get what I originally asked for. Not to mention the cost of fluids and shipping. Hopefully, they can get it right the second time. Not trying to bash or make anyone look bad, just posting about the issue I am currently going through.
Re: Street/Strip converter help. [Re: Hemi ragtop] #1336434
11/18/12 06:44 PM
11/18/12 06:44 PM
Puyallup, WA
Puyallup, WA
Measuring in the pan, its really tough to say. You're measuring the fluid after its gone through the cooler, but before it cycles through the trans. So all you really know is that your cooler is doing its job, although I'll concede that its probably all relative. I've been told to measure in the "out" line just outside the trans. Set up like this, I typically get a reading of around 175 while warm and cruising. up a long hill, and it jumps to about 200. After a pass, it typically reads about 210. I've been told by Pat Blais (torqueflite guru) that anything under 240 is just fine, @ 250 ATF starts to foam up, so if the needle goes north of 250, pull over. The fluid in your transmission could be way north of 250, but by the time it goes through the cooler and back to the pan, you could be seeing 200? 210? and think its just fine, when in reality its scorching hot in the friction zone. With all that said, most people install the sending unit in the pan, so you're in the majority.
Re: Street/Strip converter help. [Re: StealthWedge67] #1336435
11/19/12 02:39 AM
11/19/12 02:39 AM
Oh
His and Her 69's Offline
Oh
My PTC conv was not any good when I tried to spray NOS as it kept breaking. I would send it back to Kenny, rebuild trans, reinstall rebuilt conv and 2nd NOS pass broke it again. This was his 8" conv and he knew all the spec's and was built for my purpose.
Broke it 2 different times, each time when I would hit the NOS.
Sent it back, he built me a 9.5", I had told him I SOLD the NOS and it was an all motor deal now, installed it and what a pig the car was, lost .50 in ET, called him and he messed up and built it for NOS, he was sorry and gave me an 8" per John Copes suggestion, I needed the stahl to be 5600 and when it was installed it was 6100.
I called and Kenny was Nice about it, wanted to help get it right BUT I was tired of all the issues and taking the trans in and out 4 times in 1 year. I left it in and sold the car a year later.
I Like PTC/Kenny but won't go thru that again.
Just my 2cents.
Re: Street/Strip converter help. [Re: DaKuda] #1336436
11/19/12 01:19 PM
11/19/12 01:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Continental here in Calif.............1-310--674-1072.......ask for Kris. Mines a 5000+ 8" that doesn`t heat up and drives awesome on the street even for fairly long hour plus runs and works pretty nicely at the track and it`s been in my car over 10 years I think...........
Re: Street/Strip converter help. [Re: Thumperdart] #1336437
11/19/12 05:10 PM
11/19/12 05:10 PM
Willow Spring
dagohman Offline
dagohman  Offline
Willow Spring
Heres a picture of the Dart I pm'd you about, good luck with yours, NICE car
