Re: You guys care to rate my build?
[Re: JoesMopar]
#1335953
11/16/12 12:02 AM
11/16/12 12:02 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Whats it going in and and what are you planning on doing with it?
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: JoesMopar]
#1335958
11/18/12 10:27 PM
11/18/12 10:27 PM
quench not a big deal with aluminum heads--don't spend LOTS extra making you machinist get it to the thou--take a swipe at the decks to get them flat say maybe 006-008 range and bolt it together It is an aluminum head you can run Kerosene and it will not knock or give trouble. Get a True roller timing set not a fake one--Marsh Perf can sell you the entire kit cheap as ANYbody and will deliver quality parts --go with quality rockers--Marsh also has PRW rockers and while they ain't Harlands they are very nice for streeters and hot builds that don't have race spring pressures--Give Todd a call and he will do you right--he is sponsor here Moparts Connection--all of his advice is based on hundreds of quality builds with RESULTS
